Latest version
Trugmaker
Latest version
Post by Trugmaker » Fri Jun 22, 2018 10:42 pm
Pablo - don't know if this has been mentioned or experienced by any others regarding the latest upgrade. Although I upgraded a couple of weeks ago, only today I have had the needed to use it. While working on changes to my website for an hour or so, suddenly the WWB page just dropped and completely disappeared? I looked for it everywhere but found no answer or trace?? NO backup - nothing - disappeared without trace. I re-opened the new WWB programme and all the work I had done was not there, just as it was before.I assumed it was something I had done in error, so repeated the changes I made earlier - but then it happened again!!! I will re-do my work tomorrow but this time will save every few minutes. Any ideas why???
Never complain about getting old, the alternative is far worse!
Re: Latest version
Post by BaconFries » Fri Jun 22, 2018 11:05 pm
I haven't had any issues like this myself so can't offer any help. Are you using the latest version as of the 22/06/2018? if not you should download load from the following Download and see if it resolves your issue.
lpug
Re: Latest version
Post by lpug » Sat Jun 23, 2018 4:56 am
This has also occurred to me several times...I just keep saving after 5-10mins
Re: Latest version
Post by Pablo » Sat Jun 23, 2018 6:29 am
This is not normal behavior. The application should never crash/close automatically.
Does this happen even if you do not do anything?
Trugmaker
Re: Latest version
Post by Trugmaker » Sun Jun 24, 2018 8:08 am
Sorry Pablo had a family bereavement so not been back - I have only used it twice (as I explained) what I will do is leave it open while I'm not using it to test. Could what 'Bacon-fries' suggests be the answer?? I Very recently downloaded the upgrade so would expect it to be the right version.
Re: Latest version
Post by Pablo » Sun Jun 24, 2018 9:31 am
Please make sure you have the latest update. The current version is 14.0.5
Re: Latest version
Post by BaconFries » Sun Jun 24, 2018 11:16 am
The url I gave to the download is the very latest build to date as of today. If you downloaded/upgraded before this say more than a week ago or more then you are not using the latest build. Please download and install from the url I gave as this should resolve your issue.
For a full list of versions updates since release see the following:
News and Announcements
