Fussy browsers on Ipad
driedeker
Post by driedeker » Sun Jun 17, 2018 10:06 pm
Having problems on Ipad and Iphone, safari and chrome not letting pages come up when menu button pressed,
works in firefox for ipad.
works ok on pc.
Re: Fussy browsers on Ipad
Post by BaconFries » Sun Jun 17, 2018 10:13 pm
What is the url of your site so we can view and see what may be wrong...
Please read before posting:
Forum Rules - PLEASE READ BEFORE YOU POST!
7. If your website doesn't work as expected........
8. Make sure you include the URL of ............
Post by Pablo » Mon Jun 18, 2018 5:44 am
Maybe you have used 'hover' navigation, so you will have to click twice to trigger the link?
driedeker
Post by driedeker » Mon Jun 18, 2018 11:44 am
where is the hover nav setting.as yes if i highlite the button and then hit again it works
EGHJ.CO.UK
Post by Pablo » Mon Jun 18, 2018 12:28 pm
This is normal iPad behavior, because it does not support 'hover'.
You can disable hover/mouse over by using the same image/color for both images.
driedeker
Post by driedeker » Tue Jun 19, 2018 11:06 am
It was all the nav bar properties had to be the same.
So why have the options if unable to use with apple.
thanks for the quick help.
Post by Pablo » Tue Jun 19, 2018 11:57 am
Because most users use a different menu for smaller screens. Then this is not an issue.
