Carousel Sensitivity
lpug
Post by lpug » Sat Jun 16, 2018 8:17 am
Not sure if this is even possible....I have a carousel working well, is there anyway to stop mouse clicks on it and in a tablet touching it because it screws it up each time you touch or click on it during playing. I have some timers that timeout and it affects them.
Re: Carousel Sensitivity
Post by Pablo » Sat Jun 16, 2018 10:47 am
I'm sorry, there are no special options for that.
lpug
Post by lpug » Sat Jun 23, 2018 1:12 am
Sorry Pablo is it normal behavior that when you touch carousel on mobile device it stops? or have a done something incorrectly which is highly possible?
Otherwise do you suggest anything else I can use instead.
Post by Pablo » Sat Jun 23, 2018 6:23 am
Yes, this is normal behavior.
rogerl
Post by rogerl » Sat Jun 23, 2018 10:43 am
You could try something like this in CSS:
#[object id] img {
  pointer-events: none;
Don't use the square brackets, just the object id
lpug
Post by lpug » Sun Jun 24, 2018 3:11 am
Thanks Roger will this disable any actions when screen is touched on device?
So would I add this as an html element, and should it go in between head tags.
Carousel1 img {
Carousel1 is my device id
#[object id] img {
rogerl
Post by rogerl » Sun Jun 24, 2018 3:26 am
Correct on html in head tag and:
#Carousel1 img {
Just did a quick check on Google, looks like should work for touch as well
lpug
Post by lpug » Sun Jun 24, 2018 10:06 am
Roger do you mind checking whether the syntax is correct? Ive tried different combinations that google provided but when I preview the page I can see the line of code just above my webpage indicating that something is wrong.
I've tried the following
#Carousel1 img {
Carousel1 img {
#Carousel1 {
#Carousel1 img {
rogerl
Post by rogerl » Mon Jun 25, 2018 1:30 am
<style>
#Carousel1 img {
</style>
Syntax is correct. Did you have it within a style tag?
I have only used this on a slideshow and that worked fine.
lpug
Post by lpug » Mon Jun 25, 2018 1:46 am
Roger will you be so kind to check out my one page test, I have one image setup as a rollover image and have entered the html code withing the page html header. However when I preview it the image still allows hovering.
http://www.mediafire.com/file/tfl65bp5qpao2am/test.zip
<style>
#Carousel1 img {
</style>
rogerl
Post by rogerl » Mon Jun 25, 2018 2:08 am
Sorry unable to open file. not recognised by WB 12 or 14
lpug
Post by lpug » Mon Jun 25, 2018 2:15 am
You have to unzip the folder, did it this way so that you have all the relevant images.
rogerl
Post by rogerl » Mon Jun 25, 2018 3:32 am
Came to realisation this is an extension file so have installed and it doesn't work. FF & Chrome had nothing to offer so suspect fault is within extension. File contained no images, just text and code offered does not work on text just images.
I have no expertise to fault find this for you.
lpug
Post by lpug » Mon Jun 25, 2018 4:12 am
Thanks for trying anyway.
BTW- are you able to get it working on any of your projects?
