Rollover layer
ridvan
Rollover layer
Post by ridvan » Wed Jun 13, 2018 7:49 pm
Dear Pablo
Rollover layer > hover > image + Fade / overlay / color. It doesn't save.
Re: Rollover layer
Post by Pablo » Wed Jun 13, 2018 8:23 pm
I'm sorry, a rollover layer does not support overlays.
Overlays are only supported my standard layers and layout grids.
So, this option should not be in the list. I will remove it in the next update.
ridvan
Re: Rollover layer
Post by ridvan » Wed Jun 13, 2018 8:46 pm
Dear Pablo
I think you can do it. Because I saw it on some other sites. Please try it. I examine lots of sites in the day.
I'm sorry to fatigue you. as you know I'm not a professional, But will be one day.
Thank you
Re: Rollover layer
Post by BaconFries » Wed Jun 13, 2018 8:51 pm
If as you say it can be done on other sites, then give a link to those sites so it can be checked and then tell you how they achieved it.
