DIVIDER EXPERIMENTS
Dynonxp
DIVIDER EXPERIMENTS
Post by Dynonxp » Mon Jun 11, 2018 6:08 pm
I like dividers effect presented in your WB14 template „DIVIDER EXPERIMENTS“ and wanted to implement it to my page. Everything was working well, but when I combined the page with the Master Page (Master Frame (requires content place holder) the pseudo class effect disappeared. Is there any solution please? Thank you.
Re: DIVIDER EXPERIMENTS
Post by Pablo » Mon Jun 11, 2018 6:23 pm
I'm sorry, I have not tested this with master frames. So, it possible that this will not work.
Fender
Post by Fender » Mon Jun 11, 2018 7:31 pm
I just learned this (thanks to Crispy68)
If you set in the page properties of the masterframe
tab; advanced; overflow x to hidden
You can use a masterframe with the dividers, just tried myself with the
template provided by Pablo.
Fender
Dynonxp
Post by Dynonxp » Tue Jun 12, 2018 6:34 pm
Thank you. Unfortunately, I tried it, but without success.
Post by Pablo » Tue Jun 12, 2018 8:29 pm
What exactly does not work?
What is the result?
What is the URL of the page?
Dynonxp
Post by Dynonxp » Wed Jun 27, 2018 10:13 am
Hello, problem solved. Thank you for the support.
