Progress Bar Question
Nomad Soul
Post by Nomad Soul » Sun May 20, 2018 3:44 pm
Hi
I wanted to add the progress bar object to my site as a way of loading all the content before showing a completed page.
Is this possible or does the progress bar only get used for individual objects. I had a quick look at the help files but it only gave an example of associating this with onclick javascript event.
Does anyone have any more elaborate examples of how the progress bar can be used?
Re: Progress Bar Question
Post by Pablo » Sun May 20, 2018 3:50 pm
The progressbar does not do anything by itself, it is just for display purposes.
The 'logic 'must be implemented with scripts.
For example:
http://www.wysiwygwebbuilder.com/suppor ... esume.html
http://www.wysiwygwebbuilder.com/suppor ... works.html
But maybe this will be useful?
http://www.wysiwygwebbuilder.com/pace.html
wb_user
Post by wb_user » Sun May 20, 2018 7:00 pm
For example:
pablo this menu very beautiful
this http://www.wysiwygwebbuilder.com/suppor ... esume.html
how i can make that?
ruel.lago22
Post by ruel.lago22 » Sun May 20, 2018 7:35 pm
Download the template and open the project file. You can copy paste the menu to your existing project and customize it :)
Template Link: http://www.wysiwygwebbuilder.com/templates/resume.zip
