Enter Website navigation?
Hobbyist
Post by Hobbyist » Wed Apr 18, 2018 5:50 pm
It seems all the navigation functions create a new page without exiting the front page. So my question is I want a simple cover page with an "Enter" navigation that will close the front page and bring up the main pages with their menus.
So rephrased what I am looking for in the program is navigation without creating a pop up or new page in the browser. Can anyone tell me which feature I need to access to do this?
Re: Enter Website navigation?
Post by BaconFries » Wed Apr 18, 2018 6:27 pm
As you are required to always have a 'index' page for server purposes, and so that it will be indexed and found by search engines, you would then simply make what you refer to as the 'front' page from the 'index'. You would then simply add/place a image or a shape as the enter button on this with a link to the next page which would be then refered to what can be called the 'Home' page with the menu/navigation you wish to use to all other pages.
Hobbyist
Post by Hobbyist » Wed Apr 18, 2018 6:55 pm
Worked!
