Gradient not working properly
pka4916
Post by pka4916 » Wed Apr 18, 2018 12:10 am
When I have a Header and a footer on a page and set
the Header/footer/page all to the same gradient (like Red / Blue)
and the page width is 1200 or really doesn't matter.
In editing mode it looks fine, but in the browser the Page gradient is totally off.
Even when I resize it to a small screen, the header and footer the gradient works fine
but for the page it's 1 solid color at that point. (it doesn't change at all when you resize)
any way to fix this problem?
Re: Gradient not working properly
Post by crispy68 » Wed Apr 18, 2018 12:18 am
Try this:
go to Tools --> Options --> HTML --> in CSS section click the box 'Use CSS3 gradients instead of images when possible'
without the above checked, it will create an image for the gradient which has a fixed size.
pka4916
Post by pka4916 » Wed Apr 18, 2018 2:19 am
Same thing. No difference.
Post by crispy68 » Wed Apr 18, 2018 2:58 am
Can you please provide the steps you are taking to create this?
I am not sure if I quite follow what you are doing.
pka4916
Post by pka4916 » Wed Apr 18, 2018 3:07 am
Here is a link
https://www.dropbox.com/s/x1602lykec9pe ... t.wbs?dl=0
it has a header, footer and the page gradients set.
Post by crispy68 » Wed Apr 18, 2018 3:37 am
Ok, I understand what you are doing.
The reason is for the background it is creating an image called index_bkgrnd.png the size of your default view and stretching the image across the screen which does not line up with the page headers/footers.
The CSS code for the background looks like this for the <body>:
background-image: url(../images/index_bkgrnd.png);
For the page header/footer, it is using css linear-gradient which looks like this:
background: linear-gradient(to left, #FF0000 0%, #00FF7F 100%);
To get it to work, you can do it 2 ways. Delete the line in the CSS code generated for the body and replace it with:
background: linear-gradient(to left, #FF0000 0%, #00FF7F 100%) fixed;
or you can hack it by adding the following in the page html between the <head> tags:
<style>
body{background: linear-gradient(to left, #FF0000 0%, #00FF7F 100%) fixed;}
</style>
pka4916
Post by pka4916 » Wed Apr 18, 2018 4:16 am
Thanks,
So I can only do that if I export it to my drive first and then upload to the site,
or can I do it within the builder, and leave it there?
Edit: Think I found it.. I could add
<style>
body{background: linear-gradient(to left, #87CEFA 0%, #FF8C00 100%) fixed;}
</style>
under Page --> Site HTML and select the Between Tab.
