LightBox Background
Hrankov
LightBox Background
Post by Hrankov » Wed Mar 21, 2018 8:11 am
How to set Light Box Background to an Image, or specific color?
Now it is white, but I need to be background image or gray value...
Re: LightBox Background
Post by Pablo » Wed Mar 21, 2018 8:34 am
Are you referring the the FancyBox lightbox?
The background/border is made up out of images. This images are stored in the folder: Program Files\WYSIWYG Web Builder\lightbox\fancybox
Hrankov
Post by Hrankov » Wed Mar 21, 2018 8:55 am
Is there command for Background image or color like this?
width:800,
height:400,
'overlayOpacity':1,
'overlayColor':'#EEE'
I need to set LightBox background to some specific Boxes, not all of them...
Post by Pablo » Wed Mar 21, 2018 9:12 am
Did you try the code?
Hrankov
Post by Hrankov » Wed Mar 21, 2018 9:25 am
I do not know how to do it, this is the reason to ask for simple command...
Somewhere I found "background-color:#AAA#" , but it do not work...
How may I change the code for specific Light Box?
Post by Pablo » Wed Mar 21, 2018 9:38 am
width:800,
height:400,
'overlayOpacity':1,
You can enter this code in the "Settings' section of the lightbox.
If you want a different 'overlayColor' then you will need to change the '#EEE' value.
Hrankov
Post by Hrankov » Wed Mar 21, 2018 10:01 am
There is a misunderstanding.
I already use this codes on my site and know how to handle with.
I need to change the basic color of the Light Box, not the color of the site beneath it.
OverlayColor affects the site under the Light Box, but how to change the color of the Light Box?
Now it ts simple white...
Post by Pablo » Wed Mar 21, 2018 10:57 am
Hrankov
Post by Hrankov » Wed Mar 21, 2018 11:18 am
OK, thanks.
It means, there is no way to set different colors for different Light Boxes,
because if I change the images in the directory, it affects all Light Boxes.
Post by Pablo » Wed Mar 21, 2018 11:59 am
You can edit the images to modify the color.
Also note that there are many other lightbox add-ons available
http://wysiwygwebbuilder.com/lightboxes.html
