YouTube play button color
Itab
Post by Itab » Mon Mar 19, 2018 4:00 pm
Hi All,
The YouTube play button (autoplay=off) is normally gray and changes to red on hover.
This makes it hard to see when there is an image under it and visitors, especially on
a mobile device, may not realize that this is a video and not a picture.
Is it possible to change the color of the button to red at all times?
I found the button object in HTML: "ytp-large-play-button-bg" which is painted gray
with fill="#212121" and want to change it to fill="#FF0000" but don't know where and
how to do it.
Can anyone help?
Regards, Igor
Re: YouTube play button color
Post by BaconFries » Mon Mar 19, 2018 4:11 pm
You can't directly in the software, but you will be able to do so by using a HTML Editor like Notepad++. Note If you make any changes later in the software then this will get overwritten.
Post by Pablo » Mon Mar 19, 2018 4:18 pm
YouTube videos are displayed inside an inline frame and the appearance is controlled by YouTube, so I do not think you can modify the style.
rogerl
Post by rogerl » Mon Mar 19, 2018 9:49 pm
Youtube buttons (red) of various sizes are available from Youtube.
Instead of using the Youtube extension supplied with the software place a relevant image on the page with a red button on top. Put the link to youtube into the html of the button object and use button effects to animate or highlight on hover. Takes a bit more effort but you're in control.
Example:
https://www.whiteshepherdsnz.com/NewSite/page1.html
