thumbnail and larger photo
Joseph Lee
Post by Joseph Lee » Mon Mar 05, 2018 6:27 pm
Hello,
I know this is probably simple to do, but I can't figure it out.
I want to have a vertical row of thumbnails, and have the corresponding photo appear in larger size to the left of thumbnail when courser is moved over thumbnail.
Thank you in advance.
Joseph
Re: thumbnail and larger photo
Post by Pablo » Mon Mar 05, 2018 6:43 pm
Did you try the Photo Gallery?
http://wysiwygwebbuilder.com/photogallery.html
protectourlands
Post by protectourlands » Mon Mar 05, 2018 6:59 pm
Add the thumbnail (thumbnail1 for example)
Add the larger version (larger1 for example). Right click > Hide
Open tumbnail1 manager:
Events:
onmouseover > Show > larger1
onmouseout > Hide > larger1
Repeat for each thumbnail and larger version
Joseph Lee
Post by Joseph Lee » Tue Mar 13, 2018 8:05 pm
Thank you both very much for replying, @protectourlands, it works!! Thank you! :D
Joseph Lee
Post by Joseph Lee » Tue Mar 13, 2018 8:19 pm
Followup question please @protectourlands?
Would it be possible to have a default "large" image visible before any mouseover occurs?
UPDATE:
I think I figured out how to have a default large image show. Make sure image is same size, place it directly on top, move it back, make it visible. Now it shows by default, until mouse over occurs.
I know there must be a cleaner way to do it, but this appears to work for me!!
protectourlands
Post by protectourlands » Tue Mar 13, 2018 8:19 pm
You're welcome. Don't be afraid to try "Show With Effect" instead for some really cool effects.
Users browsing this forum: No registered users and 26 guests
