breakpoints
Bazza2
breakpoints
Post by Bazza2 » Sat Feb 24, 2018 5:28 am
I am setting up a site with 320 and 800 breakpoints.
I am using a number of layers on the main page to hold certain text information with different background colours.
It happens more on the 320 break point in that all the layers get jumbled together mixing what should be in them with other layers and even joining layers together making huge layers. Takes ages to sort them out so I can finish the page size as 320.
Short of doing away with the layers am I doing something incorrectly or am I missing something. Perhaps the procedure is wrong.
Any guidance appreciated
Re: breakpoints
Post by Pablo » Sat Feb 24, 2018 7:54 am
Did you try the 'Restore position' or 'Scale' tools in the Object Manager?
viewtopic.php?f=10&t=63817
Bazza2
Re: breakpoints
Post by Bazza2 » Sat Feb 24, 2018 9:23 pm
Thanks Pablo
I read up on those notes and found that the restore position is located in the Object Manager Context Menu.
The object manager left hand size of the page does not contain a Context Menu.
Where do I find it
Re: breakpoints
Post by Pablo » Sat Feb 24, 2018 9:31 pm
Did you right click inside the Object Manager?
Bazza2
Re: breakpoints
Post by Bazza2 » Sat Feb 24, 2018 10:06 pm
Missed that-
I am going out for 5 hours so I will test when I get back and hopefully it will unscramble the jumbled lot of text and layers..
barry
Users browsing this forum: No registered users and 7 guests
