Issue with image link on layout grid
Maria Flores
Re: Issue with image link on layout grid
Post by Maria Flores » Thu Feb 01, 2018 3:59 am
crispy68 wrote:
Thu Feb 01, 2018 3:47 am
It appears when the link is assigned to the image, the link covers the entire container/column in the layout grid where the image is in and is active in Chrome and FF. In IE and Edge, it behaves as intended. I'm not sure if this is browser thing or something else. Maybe Pablo can weigh in on this.
I agree. Let's see what Pablo says about this, maybe it's just a browser bug :mrgreen:
GrahamW
Post by GrahamW » Thu Feb 01, 2018 5:34 am
I just did a test and opened up in google chrome and this is what I found.
As Chrispy pointed out setting full width=True it will place the hand on either side of the image and allow it to be clickable. So I left my test image set to full width and to the right of that setting I put 1920 in my maximum width, this then only allowed the image to be clicked on when set to full width. You may have to play with the maximum width setting till your happy with the result.
hope this helps
Graham
Post by Pablo » Thu Feb 01, 2018 7:22 am
The max-width applies to the image, not to entire object. The image is inside a container otherwise it could not be full width and still have a max-width.
So the link (which is a parent element of the image) may be wider.
Maria Flores
Post by Maria Flores » Thu Feb 01, 2018 9:23 pm
Hi Pablo
thanks for answering, but how can i overcome this? what is the correct thing to do?
thank you once again
Post by Pablo » Thu Feb 01, 2018 9:37 pm
You cannot change this, this is how it works when using 'full width'.
Maria Flores
Post by Maria Flores » Thu Feb 01, 2018 9:44 pm
i see
so the best option should be breakpoints with multiple image sizes in each one without the option of the layout grid?
Post by Pablo » Thu Feb 01, 2018 10:03 pm
Using breakpoints will not make a difference.
But is this really a big issue?
Basically 'max-width' limits the image rendering size, but it does not limit the actual 'box' which is full width and therefor covers the entire space.
Maria Flores
Post by Maria Flores » Thu Feb 01, 2018 10:08 pm
Not a big issue so to speak, but i wish that this could be done in another way, but i can understand that this is how it is. Thank you.
