problem med mobile website
geronimo
Post by geronimo » Sun Dec 31, 2017 4:00 pm
Hello. I use WB12, I have also mibile web site and it worked just fine. I wasnt doing something on it long time, maybe a year. Now I tryed to update 2 links from it and they published in wrong way, they become links for normal computer, not mobile device. I have bild mobile site in same project where my normal site is.
Maybe you can help me with instructions how to fix that when I publish is coming right mobile site
www.uppsala-hem-elektriker.com
is my site
If you try to open the home page from mobile device you will see how it is opening, very smal. At the same time deferent links in mobile site projekt opens in right way, I just bublished the home page(mobile) and it whent in wrong way
Re: problem med mobile website
Post by Pablo » Sun Dec 31, 2017 4:20 pm
Everything seems to be ok as far as I can tell.
What is it suppose to look like?
Note that you website is not really optimized for mobile devices, it just redirects to 320 version of the page.
However most mobile screen are much wider, so in that case the layout will look very small.
I think you should consider implementing breakpoints or layout grids to make your website future proof.
geronimo
Post by geronimo » Mon Jan 01, 2018 3:05 pm
Hello again, thanks a lot for the help. I just got email from you with mising code, now this 2 links working well. What I figer out is that this code is mising on all the links but they look beter. I am gona work on it to make it beter. Thanks
kenmed
Post by kenmed » Tue Jan 02, 2018 3:23 pm
Se över stavning och särskrivning på sidan. Ger bättre intryck.
ken
Bluesman
Post by Bluesman » Tue Jan 02, 2018 4:05 pm
Håller med "kenmed" ... Mycket viktigt! :D
"Make My Day"
See my Website
kenmed
Post by kenmed » Tue Jan 02, 2018 5:35 pm
Se din svenska sidas meny, Omoss :D Trång menyrad?
ken
Post by BaconFries » Tue Jan 02, 2018 5:47 pm
@kenmed and bluesman can we use English please!! as this section of forum is English.
kenmed
Post by kenmed » Tue Jan 02, 2018 6:22 pm
ok. Writing about spelling.
kenmed
