Copyright symbol in banner
MGD4me
Post by MGD4me » Fri Dec 22, 2017 6:34 pm
I have created a MasterPage-footer, which is a simple banner with some text. I haven't found a way to include the copyright symbol in a banner. In a normal text field/box, I can go to Format >> Symbol, and the copyright symbol is included in the list, for normal text boxes.
As a workaround, I can overlay a text box with the copyright symbol on top of the banner, but the text alignment never seems to look quite right after publishing.
Is there any way to add the symbol as part of the text banner?
WWBman
Re: Copyright symbol in banner
Post by WWBman » Fri Dec 22, 2017 6:44 pm
You could create a temporary Text Object and insert the copyright symbol.
Then highlight the symbol and copy it.
Then paste it into the banner text.
Delete the text object.
Post by Pablo » Fri Dec 22, 2017 7:04 pm
For the banner you can use the standard Windows keyboard input to insert a copyright symbol:
Alt+0169
https://www.thespruce.com/copyright-sym ... ac-2688246
MGD4me
Post by MGD4me » Fri Dec 22, 2017 7:07 pm
Excellent!
That worked... Thanks.
MGD4me
Post by MGD4me » Fri Dec 22, 2017 7:10 pm
Pablo... we were both typing at the same time... :o)
I was responding to WWBman's suggestion, which worked for me. I will try out your solution later. Thanks.
MGD4me
Post by MGD4me » Fri Dec 22, 2017 7:17 pm
I'm happy to report that both methods work perfectly. It's just a matter of preference!
Thanks, to both.
alex4orly
Post by alex4orly » Wed Jan 30, 2019 12:06 am
I tried adding Copyright symbol under Windows 10, not working with ALT+0169
Any other options?
Cheers
alex4orly
Post by alex4orly » Wed Jan 30, 2019 6:19 am
All OK - after further looking around, found out that the 0169 - MUST be typed on the numeric keypad...
Oh well
Cheers
