dioganal section design for page
Bart Design
Post by Bart Design » Mon Dec 18, 2017 10:57 am
Hi is there annyone that can help me out! I like to make a dioganal section in a webpage. I like to make this full lenght... in a layer?? Annyone... Thanks in advange.
Re: dioganal section design for page
Post by Pablo » Mon Dec 18, 2017 11:08 am
Bart Design
Post by Bart Design » Mon Dec 18, 2017 6:40 pm
Thanks pablo, but i mean horizental and than instead of 90 degrees, i like to make it for example 115 degrees. I try everething without anny succes.
Hope you have annouther solution for me.
pajadt
Post by pajadt » Tue Dec 19, 2017 3:05 pm
Hi Bart
that what you want require css coding, any way you can contact me and i see what is need
bburgess
Post by bburgess » Tue Dec 19, 2017 11:32 pm
Hi Bart, if you mean this: https://www.burgessfreelancer.ga/design ... y_concept/
Just yell and I will post the small bit of CSS that makes it work. Sorry at Work at the moment with out access to WB
Cheers
BB
Bart Design
Post by Bart Design » Wed Dec 20, 2017 1:57 pm
Thank you guy's for replying to my question. If you can help me out with de css coding i will apresiate this a lot. Can i use the code for a shape and also a layer? And how and were to install! Thanks in advange
Bart Design
Post by Bart Design » Wed Dec 20, 2017 2:13 pm
Cheers
BB
Hi bburgess, what i also like on your site, is the way how it zooms in verry slowly on a picture! That looks really great! Is that also css coding or can i do this with the WB? Thanks i like to hear from you. Greeting Bart Design
bburgess
Post by bburgess » Wed Dec 20, 2017 8:14 pm
The zoom images are from a Block in in WB I am running 12.3.0 but it should be in 12.0 and up I think, it comes with the Zoom Background HTML Element so its Pablo who's done all the hard work on that one :)
The CSS to Skew is:
Object HTML > Custom Style > Paste in code
-ms-transform: skewY(10deg); /* IE 9 */
-webkit-transform: skewY(10deg); /* Safari */
transform:skewY(10deg);
You just adjust the degrees, either -10 -15 -20 et cetera or 10 15 20.
On the page I have made a layer 10 degrees and a picture -10 degrees so its possible to make different angles with some playing.
Hope this helps :)
Cheers
BB
Bart Design
Post by Bart Design » Thu Dec 21, 2017 6:51 pm
Thanks bburgess, i try it out and it workes! Nice... This wil give a extra demention to my site! Thanks again!
Users browsing this forum: crispy68 and 8 guests
