show object after page loadig
tom248
Post by tom248 » Fri Dec 01, 2017 5:26 pm
How is it possible to show an element on the site 5 seconds after pageloading - with the effect "fade in"
Re: show object after page loadig
Post by Pablo » Fri Dec 01, 2017 6:08 pm
You can use a timer for this:
http://wysiwygwebbuilder.com/timers.html
tom248
Post by tom248 » Fri Dec 01, 2017 9:00 pm
thanks :) i didn't found this tool...
But now i have also a Problem with the layer object.
Mode: Stick-layer , Orientation: Bottom right -> and after 5 second when the pages has load, you can
see the object on the right place.
But when i only change the orientation for example to center-right, it dosn't work.
the object is somewhere on the site....
Post by Pablo » Fri Dec 01, 2017 9:36 pm
A sticky layer is controlled by JavaScript, so it may not respond to event actions (depending on which options you have selected).
tom248
Post by tom248 » Fri Dec 01, 2017 9:51 pm
in the meantime i have deleted all Events and the timer, but the roblem is still there....
Post by Pablo » Sat Dec 02, 2017 7:50 am
In that case I need your project to be able to help you, so I can see what you have done.
Users browsing this forum: andyp and 13 guests
