Smooth transition
maxlan
Smooth transition
Post by maxlan » Mon Oct 31, 2016 3:37 pm
Hi.
How to achieve the effect of smooth transition from one page to another using wwb.
Thank you
Re: Smooth transition
Post by Pablo » Mon Oct 31, 2016 3:46 pm
HTML does not have smooth transition between pages. This is only possible if the content is loaded by script (via AJAX).
maxlan
Post by maxlan » Mon Oct 31, 2016 3:57 pm
Pablo wrote:HTML does not have smooth transition between pages. This is only possible if the content is loaded by script (via AJAX).
It can be an example or a link?
Post by [RZ] » Mon Oct 31, 2016 4:01 pm
perhaps this may be useful? viewtopic.php?f=53&t=55937
(also jQuery-free may soon be available)
Post by Pablo » Mon Oct 31, 2016 4:17 pm
maxlan
Post by maxlan » Mon Oct 31, 2016 4:53 pm
$(document).ready(function() {
$("body").css("display", "none");
$("body").fadeIn(500);
$("a.fade").click(function(event){
event.preventDefault();
linkLocation = this.href;
$("body").fadeOut(500, redirectPage);
function redirectPage() {
window.location = linkLocation;
</script>
This code works from the first page to the second, the second to the first no.
Post by BaconFries » Mon Oct 31, 2016 5:09 pm
Please note that it is out with the scope of the forum to assist with custom code. If you wish to use it is generally understood you understand how to use and how it fix any errors.
