included files not working of folder rename
GrahamW
Post by GrahamW » Sat May 11, 2019 9:04 am
I have noticed if you build an extension and have some included files then you decide to either rename or move that folder the included files in a WB project no longer upload with the extension because the path has been broken.
Is there a way to fix this?
Graham
Re: included files not working of folder rename
Post by Pablo » Sat May 11, 2019 10:15 am
There is no way to automatically update the locations, you will need to update the paths yourself.
GrahamW
Post by GrahamW » Sat May 11, 2019 10:23 am
thanks Pablo thats what I have done
Graham
