Why is the bitwise «or» (vertical line) removed
dlod
Post by dlod » Thu Mar 15, 2018 8:37 am
Hello!
В options -- Add Option -- after the sign: ~ real
Why is the bitwise «or» ( | vertical line) removed?
There is a way how you can insert a bitwise «or» into the real value?
Re: Why is the bitwise «or» (vertical line) removed
Post by Pablo » Thu Mar 15, 2018 8:53 am
The pipe character is used internally to separate the display and real value. It cannot be used in the data.
dlod
Post by dlod » Thu Mar 15, 2018 9:21 am
Thanks for your answer
