Disable case-sensitive for log-in user name
TIP:
jeff11214
Post by jeff11214 » Sun Jul 22, 2018 8:07 pm
Is there a way to Disable case-sensitive for log-in user name?
Re: Disable case-sensitive for log-in user name
Post by Pablo » Sun Jul 22, 2018 8:14 pm
There is no standard solution for this, you will need to edit the code for this yourself.
