Login Failure
TIP:
JohnR
Login Failure
Post by JohnR » Wed Mar 28, 2018 4:20 pm
I have two pages on my website to which I want restricted access. Figured a Login with a redirect was the best way to go. I have created the database, using WYSIWYG, and can download and edit it with no trouble using the admin panel within WYSIWYG. When I publish the page (Ridgley.ca/ridgley1.php) the admin panel has a message on it saying 'database not found' and the login always goes to the error page. Sort of puzzled as to why I can download and edit the database from within WYSIWYG but the database is not found when I publish? I have checked permissions on the server and the database is set to 0777. All guidance greatly appreciated.
Re: Login Failure
Post by Pablo » Wed Mar 28, 2018 5:57 pm
Usually this indicates that database is on the wrong folder on the server.
Make sure the settings match the structure of your website.
JohnR
Re: Login Failure
Post by JohnR » Wed Mar 28, 2018 6:47 pm
I had the folder AND file name for the database. When I removed the folder name it worked.
Thanks Heaps!
It's great to have such good support!!!
