Signup. "Use Placeholders": before OR after converting to standard form?
TIP:
Aris
Post by Aris » Sun Sep 17, 2017 2:35 pm
Hi.
In Signup form (before converting to form) there is the choice: Use Placeholders: True / False.
My question is:
I must make the choice in Signup form before converting it to standard form
OR
I have the ability to add placeholders after converting the Signup form to standard form?
Thank you.
Re: Signup. "Use Placeholders": before OR after converting to standard form?
Post by Pablo » Sun Sep 17, 2017 3:21 pm
After converting the signup to a standard form you can set the place holder text in the properties of the editboxes.
Aris
Post by Aris » Sun Sep 17, 2017 3:24 pm
Thank you, Pablo.
Aris
