Honey pot and Login Tools?
TIP:
bburgess
Post by bburgess » Tue Apr 25, 2017 2:22 am
Hi Pablo :)
Do you know if I can use the Anti Spam Honey Pot technique in conjuction with the Login Tools > Signup Object?
Or will the database have a meltdown?
Honey Pot: Place an edit box into the form, give it an enticing name, hide it from humans, if its filled in its a spam bot.
can not really test this as I have no SPam Bots :D
Cheers
BB
Re: Honey pot and Login Tools?
Post by Pablo » Tue Apr 25, 2017 6:37 am
It may work, but the code to ignore the honey pot input needs to be implemented by yourself. There is no standard option for this.
Post by [RZ] » Tue Apr 25, 2017 11:44 pm
@bburgess
hi, it is not as simple as it seems and nowadays it is easily fooled by bots
as i am not so known (lol) my proprietary method (based on honeypot variants and other techniques as well) stopped 100% the bot-based spams (my forms were attacked by 600 hacking attempts per hour during 3 days at different time-frames)
perhaps you may want to take a look at this: viewtopic.php?f=53&t=59001
it works both visually and silently behind the scenes
bburgess
Post by bburgess » Wed Apr 26, 2017 12:26 am
@Pablo Thank you, I will have to have a play :)
@RZ Thats a good looking CAPTCHA mate thanks for pointing me in the direction!
Cheers
BB
