Edit Profile object
TIP:
TIP:
Edit Profile object
I created a login system using the WWB objects.
Converted the Edit Profile object to a form
Now, I am trying to add an input field (checkbox) to the form, but it seems the only way is to edit the HTML page manually, which I don't like...
Is there another way?
Cheer
Cheer
Re: Edit Profile object
Did you ask the same question a couple of days ago?
I have been sending you dozens of emails about this to help you
But anyway in the mean time in version 12.0.2, the checkbox will be automatically converted.
I think his question is:
Is it possible to add a checkbox filed to an edit profile object which is already converted to form? Or should we manually edit the converted form script to accept newly added checkbox field?
~ Remain Curious
and Keep Learning ~
_________________
and Keep Learning ~
_________________
Yes Biju,
That is exactly my question
Didn't I already answer this?
viewtopic.php?f=26&t=76475
No, this is not the answer.
What i wrote there is only applicable to input fields that were created in the object itself before being converted to a form.
I have it now as a form and wish to add another field, but other then adding the field in html section, it does nothing in the php code like the databade functionality.
So?
So?
If you add another field after the conversion then you will also need to update the script. of course this cannot be automated, this can only be done manually.
OK, Thanks
I will start it again and let it be converted, I prefer that better than editing the code and risking it being overwritten
Cheers
Cheers
