login: check box and Remember me in layout grid form
TIP:
Aris
Post by Aris » Mon Mar 27, 2017 7:59 pm
Hi.
Converting a login tool to Form and pasting its form elements to a layout grid --which I have make it Form (with enable form)--, I cannot put the check box and the Remember me in the same line (like the original login).
What I must do?
Thank you.
Re: login: check box and Remember me in layout grid form
Post by Pablo » Mon Mar 27, 2017 9:00 pm
Correct. Form elements are block elements so they are always full width when floating.
What you can try it to nest another layout grid with two columns.
maxime
Post by maxime » Mon Mar 27, 2017 9:16 pm
you may also Not convert to form.create a page with the login form and then Use an inlineframe in your layoutgrid
Aris
Post by Aris » Tue Mar 28, 2017 6:50 am
Thank you,Pablo.
It works fine!
Aris
Post by Aris » Tue Mar 28, 2017 6:53 am
Thank you, maxime.
But it does not solves the problem with the long distances between Labels and Form elements.
maxime
Post by maxime » Tue Mar 28, 2017 1:38 pm
yes it does, i have done it. I am not in my office i may give you an exemple later this evening.
when you use the login object the distance between Labels and Form elements is ok then why suddenly it will be not be ok if you use it Inside an inline frame ?
but since you have resolved your problem with the nested layout grid it is ok.
