EXTENSION Exit PopUp Pro for Webbuilder 12 and above
me.prosenjeet
Post by me.prosenjeet » Sun Apr 08, 2018 1:42 pm
What is an EXIT POPUP?
An Exit popup is a window that shows dynamically when a visitor goes to close your website.
The extension detects if the mouse of a user and when the user tends to move away from the page, it shows a popup box.
Visitor mouse movements are tracked, and when their cursor moves outside the page boundary, the popup is triggered.
This popup can be anything that you want to use in the popup (full HTML control).
Exit intent popups are used to hopefully retain visitors that would otherwise be lost.
It can be used to…
Increase your conversion rates!
Give visitors reasons to stay!
Grab your users’ attention!
Read details and view a Live demo:
http://lucknowwebs.com/exit-popup-pro-e ... -and-above
me.prosenjeet
Re: EXTENSION Exit PopUp Pro for Webbuilder 12 and above
Post by me.prosenjeet » Thu Jan 10, 2019 6:02 am
Extension updated
