My Sql Various Extentions
Umesh1710
Post by Umesh1710 »
Hi Users,
I have made some mysql extentions for advanced users like
1.My sql count extention
Using this extension you can count filter base MySQL data Raw.
2.My sql sum extention
Using this extension you can able to sum of specific MySQL data table field.
3.My sql Google column chart
4.My sql Google pie chart
5.My sql Google Bar chart
All charts extension have been used google chart API.which is a free and open-source API.you can build attractive charts using these extensions.as google chart API is rendring chart through Google chart drawing tool,you need to on your net.
6.My sql Marquee
You can set your MySQL data as a marquee
all script are custom made, no third party licensing’.for all extension s you needs to just set your database connection s and field property only.
All extentions are useful to makes dynamic dashboard using mysql data
You can downloads all extentions free off cost from
https://drive.google.com/drive/folders/ ... sp=sharing
WWBman
Re: My Sql Various Extentions
Post by WWBman »
For the Pie Chart you have included the .xwb file instead of the .wbx file.
It would be useful if you included a help/pdf file for each extension.
Umesh1710
Post by Umesh1710 »
Thanks WWBman for your suggestions.
Currently I m making help files for all extensions.
I will be shortly updated it.
Revised file of Pie chart extension updated
As previously pointed out to you the rules before posting.
In the pdf documentation :
* Write how to use + terms to use (paid or free) in the pdf file,
(than people know what todo if they use your extension!)
*** MUST READ *** Please read this before posting extensions
Umesh1710
Post by Umesh1710 »
Thanks Bacon for your suggestions.I have uploaded all help files with demos/Terms and conditions.
