jor_gridRip 3.0
GrahamW
Re: jor_gridRip 3.0
Post by GrahamW » Mon Oct 02, 2017 2:45 am
hI,
I use WWB12 and I have notices with this script google chrome gives a warning saying this. You only see the warning when uploaded not on preview of site.
You are trying to load scripts from unauthenticated sources
Graham
jordan
Re: jor_gridRip 3.0
Post by jordan » Mon Oct 02, 2017 1:59 pm
hI,
Graham
hello GrahamW,
I do not see such message when using jor_gridRip
there is nothing unsafe about the script, I wrote it myself and use it myself, it does not load or use any other (external) script
- does this happen for you when you try the - jor_gridRip_easystart project - online ?
- can you post a link on which this occurs for you and maybe a screenshot with the message ?
GrahamW
Re: jor_gridRip 3.0
Post by GrahamW » Tue Oct 03, 2017 1:36 am
Hi Jordan,
thanks for getting back to me.
open google chrome then view this page
https://www.grahamscomputers.net/testin ... tanks.html
look in the very top right hand corner near the bookmark star you will see it. Your gridrip script is the only one on this page and you can see it when you go to the tank quote section of the page.
If I remove the script from the page the error goes away
Graham
Re: jor_gridRip 3.0
Post by crispy68 » Tue Oct 03, 2017 2:13 am
This is what I see on my chrome for your site after I load the script:
I've used GridRip on a site here:
http://www.losreyesmarietta.com/menu.html
and I don't have that issue popping up on my chrome like your site.
since your site is using https: have you asked your host as to why this is coming up? I would think if it was the script itself, then I would see it on my site as well.
Per the Google notes it says:
You'll see a warning if the content you're trying to see is dangerous or deceptive. These sites are often called "phishing" or "malware" sites.
Phishing and malware detection is turned on by default. When it's turned on, you might see the following messages. If you see one of these messages, we recommend that you don't visit the site.
----This page is trying to load scripts from unauthenticated sources: The site you're visiting is not secure.
Looks like they give you an option to request a review of your site if it is being marked as dangerous.
jordan
Re: jor_gridRip 3.0
Post by jordan » Tue Oct 03, 2017 12:09 pm
Hi Jordan,
Graham
hi GrahamW,
jor_gridRip is not the only script on your page
all the mixed content blocking that I can see on your site is from - fonts.googleapis.com
can you post a link with my - jor_gridRip_easystart project (found in my download) - online - to see if this occurs with just jor_gridRip ?
#crispy68 - thanx for your input:)
GrahamW
Re: jor_gridRip 3.0
Post by GrahamW » Wed Oct 04, 2017 7:38 am
Hi Jordan,
where is the easy start project I cant locate it can you give a link please
As to the issue that Crispy was mentioning that is not the issue its over the right had side of the page. If I could upload images on this forum I would show a screenshot of the issue but i have no way up posting an image
This is what I see Jordan, if I remove gridrip it goes away, it only happens in Chrome any other browser I use I dont see it (IE, EDGE)
https://www.screencast.com/t/gYmdvb28pFu
Graham
GrahamW
Re: jor_gridRip 3.0
Post by GrahamW » Wed Oct 04, 2017 9:04 am
Hi Jordan and Crispy
I found where the issue is with gridrip.
Everything works perfect on any web page with it but in WWB if you go into options>HTML then at the bottom of the page under web fonts select
use Google Fonts for non web-safe fonts.
Then upload the page and you will then see the image I posted in my previous post in the top right corner of your Google Chrome Browser.
Graham
jordan
Re: jor_gridRip 3.0
Post by jordan » Wed Oct 04, 2017 5:19 pm
so this only occurs when jor_gridRip is on your page + google fonts is enabled + https is used ?:\
please try this ...
in jor_gridRip there is a - margin fix - option, set it to true - (SETUP GRIDRIP > SETTINGS > margin fix > true)
does that help ?
GrahamW
Re: jor_gridRip 3.0
Post by GrahamW » Fri Oct 06, 2017 3:31 am
Hi Jordan,
i made that change and it made no difference.
I can confirm it only happens when google fonts is enabled + https is used
I uploaded the site to its correct location that is only http and google fonts enabled and it works perfect
Graham
jordan
Re: jor_gridRip 3.0
Post by jordan » Fri Oct 06, 2017 2:06 pm
Hi Jordan,
Graham
glad to hear that works for you! ...
but, I do not see that you have changed the - margin fix - on your test site ?
always post a revised version so I can see the result please:\
other then that I'm clueless, I don't see how jor_gridRip can be the cause of this behavior ?
can you please post two tests for me ...
1. test ONE
leave jor_gridRip on the page, but, remove the entry that creates the effect
so, simply jor_gridRip on your page, that does nothing, no effect
2. test TWO
remove jor_gridRip completely
two live test at the same time please, so I can see the result, - very strange this, hm:\
GrahamW
Re: jor_gridRip 3.0
Post by GrahamW » Wed Jul 04, 2018 10:29 am
Hi Jordon
is there any way to make the transition a bit smoother
https://www.grahamscomputers.net/testin ... staff.html
if you cn test it on the and tell me what I need to change that would be great
Graham
jordan
Re: jor_gridRip 3.0
Post by jordan » Wed Jul 04, 2018 12:24 pm
hello GrahamW,
hmm, AFAICS on that page your using jor_gridRip directly on WB Text objects ?
jor_gridRip is made to be used on WB Layout Grids exclusive
if you want a text object to open then the text object must be placed inside a grid, - then target the grid
solution: use nested grids, target the Grid that holds the text
does that help?
GrahamW
Re: jor_gridRip 3.0
Post by GrahamW » Wed Jul 04, 2018 12:53 pm
it actually is inside a nested grid.
i have it on another site and it works perfect all I did was copy the grid from one project to another and it has identical settings but the other site has no issue like this one
Graham
jordan
Re: jor_gridRip 3.0
Post by jordan » Wed Jul 04, 2018 1:23 pm
Graham
AFAICS your targeting WB Text objects, your targeting - megantext, romolatext, etc
which to me seem to be WB Text objects
they are placed inside a grid named - LayoutGrid2 - but your not targeting this LayoutGrid2
instead you are targeting the Text object themselves
code on your page reads:
$.jor_gridRip ({toOpen:'megantext',to ...
on the page that it does work correct you ARE targeting the Layout Grid (=target is LayoutGrid2)
$.jor_gridRip ({toOpen:'LayoutGrid2',to ...
GrahamW
Re: jor_gridRip 3.0
Post by GrahamW » Thu Jul 05, 2018 6:12 am
yes that is correct as the grid is called megantext, Romolatext and so on
