MULTI RESPONSIVE MENU
Patrik iden
Re: MULTI RESPONSIVE MENU
Post by Patrik iden » Mon Aug 03, 2015 9:10 pm
burglar wrote:My site contains a fixed header and footer. Master objects does not allow for this. Is there any other way round it?
Not that i know about.
fr02774
Post by fr02774 » Mon Aug 03, 2015 10:35 pm
Patrik iden wrote:Hello,
(in page test, i don't want to click on menu 'le foot' for exemple). Answer: do not use any link on the le foot main menu button.
How can i do for it begin at 0,99, and when i scroll, it up to 0,0. Answer: You can't.
you can have submenus on other submenus.
I have no documentation. Just read the info on every option.
Have you tried the WWB CSS Menu?
hello,
all has been corrected, but it stay the problem with submenu
- when i choose "le foot" i have lot of submenu. When i select a submenu, it is display on a strange way, mix with the old menu. Can i display submenu, righter is folder ?
How can I shif (padding) the levels of submenu ? what is the option ?
i search to have this
menu
submenu level 1
submenu level 1 - submenu level 2 - submenu level 3
submenu level 2
the problem is here --> http://marius-david.fr/presentation2.php menu "le foot" and submenu a year
thanks
Laurent DAVID
Webmaster of http://marius-david.fr/
Patrik iden
Post by Patrik iden » Mon Aug 03, 2015 10:43 pm
You can't have submenus on other submenus. This is only a 2-level menu.
Vlastimil
Post by Vlastimil » Sun Mar 13, 2016 5:58 pm
Hi, when I use in Back Button Text some Czech characters (project is based on in UTF-8), the czech characters are not displayed correctly.
Patrik iden
Post by Patrik iden » Sun Mar 13, 2016 6:34 pm
Vlastimil wrote:Hi, when I use in Back Button Text some Czech characters (project is based on in UTF-8), the czech characters are not displayed correctly.
Sorry i dont know wy this is.
Vlastimil
Post by Vlastimil » Fri Mar 18, 2016 3:03 pm
Thanks for your answer.
cdasupport
Post by cdasupport » Wed Sep 13, 2017 11:32 am
Hi gys'n gals
May I be so bold to ask, all the files that are in the download, how am I suppose to install this and where do all the files and folders goto ?
Jase
Patrik iden
Post by Patrik iden » Wed Sep 13, 2017 6:20 pm
You only use the Extension file.
Users browsing this forum: No registered users and 5 guests
