Breakout (FREE)
Adendum
Breakout (FREE)
Post by Adendum » Sat Feb 08, 2014 4:35 pm
The final extension (Number 41) from the library of extensions by Adendum.
However, although the extension was created by Adendum the guts of it are entirely down to Pablo. No matter what I did when hacking into a layer I couldn't reproduce the same effect in an extension .... until Pablo came to my rescue and supplied the jQuery that unravelled the secret.
The purpose is simple - this extension creates a layer that breakouts of the constraints of a page so that the layer will fill the browser width. It is designed to call in another page (internal or external) using EITHER an inline frame or using the <object> tag and was primarily developed to complement the Snazzy Maps extension but it can be used with many other types of page. However, for the best effect the page called in to a Breakout page should fill the browser entirely.
There are four examples on the demo page and additional examples in the Snazzy Maps page.
There will be NO FURTHER development of this extension other than bug fixing. What you see is what you get, so please do not ask for additional features or options to change the current feature set.
Have fun and let your creativity loose!
Death to Internet Explorer!
jordan
Re: Breakout (FREE)
Post by jordan » Sun Feb 16, 2014 10:29 pm
. 8) . - THX for your index update mail Paul! - THX for all your great extensions;)
googledat
Re: Breakout (FREE)
Post by googledat » Mon Feb 17, 2014 6:38 am
Paul, breakout is a worthwhile extension. Thanks for all your hard work. Can this extension be used with version 8?
Steve
Adendum
Re: Breakout (FREE)
Post by Adendum » Mon Feb 17, 2014 12:44 pm
It was built using Extension Builder 4.2 so I doubt it.
stamjoe
Re: Breakout (FREE)
Post by stamjoe » Wed Feb 19, 2014 7:02 pm
Amazing stuff man!!!!
Thanks very much!!!!
Joe
Adendum
Re: Breakout (FREE)
Post by Adendum » Wed Feb 19, 2014 7:15 pm
99% of the credit goes to Pablo on this one. It's his jQuery - read the original post.
DavidMoshe
Re: Breakout (FREE)
Post by DavidMoshe » Fri Jul 11, 2014 2:41 pm
thanks for cool extension. can you please tell is it possible to use this also with normal gmaps ?
i cann not find anywhere gmap API key for sneezy maps :(
maybe you know how to find it, i also looked on google but only thing i find is stupid wiki telling about licences!
best regads
Adendum
Re: Breakout (FREE)
Post by Adendum » Fri Jul 11, 2014 3:08 pm
DavidMoshe wrote:thanks for cool extension. can you please tell is it possible to use this also with normal gmaps ?
best regads
You can use Breakout for anything.
The API is easy to find - I have even provided links to get one from within the demo and the extension PDF.
