cloud zoom extension
pavlos1
Post by pavlos1 » Wed Jul 04, 2012 5:09 pm
I am trying to implement cloud zoom extension in some pages of a project.
What I am trying to do is to have some pages with rows of item photos and apply the cloud zoom magnifying.
As far as I know, I need to repeat the extension for each photo.
My question is if there is a limit in repeating the extension to avoid problems in page loading.
Thank you
Re: cloud zoom extension
Post by BaconFries » Wed Jul 04, 2012 5:26 pm
Palo might be best to post your question directly in the original thread of the extension so that you will get a answer
bubblegumweb
Post by bubblegumweb » Thu Sep 21, 2017 6:58 pm
Hi all, I have just done a WYSIWYG12 update and now my Cloudzoom is not working I get the message saying "Failed to load: CloudZoom.wbx!" But i still see the extension files in the "SYSTEM" "EXTENSIONS" folder? Any idea's please?
Regards
Gary
bubblegumweb
Post by bubblegumweb » Sat Sep 23, 2017 8:56 am
Just an update folks.
I have sorted out why my "Cloud Zoom Extension" was not working. For some reason I had 2 folders which hold all my WYSIWYG projects in them on my computer, and I was using the wrong folder to open my WYSIWYG project creations. As soon as I swapped to the other folder to open my WYSIWYG projects all is working fine the extension works again.
Needless to say the culprit folder has now been removed :)
Regards
Gary
