Camera Slideshow (FREE)
Adendum
Post by Adendum » Sun Apr 29, 2012 4:13 pm
This extension is based on Manuel Masia's Camera Slideshow. An extremely versatile slide show that allows multiple customisations to both the look and feel as well as the functionality. Options to display a pie loader or bar, change pie or bar positions, thumbnail positions, 24 transition effects and a random option, 10 overlay images, 28 different skins for controls, full screen or normal, captions and full styling capability. And that just scratches the surface!!!
PLEASE take the time to read this help file before you launch into this extension.
Demo available from my demo site. Extension available from the main WWB extension site and the demo site. See links in signature.
Death to Internet Explorer!
pewe
Re: Camera Slideshow (FREE)
Post by pewe » Sun Apr 29, 2012 5:52 pm
Thanks.
Looks interesting.
By the way, what is it you used to create the 'Jump To' scoll menu on your site.
Post by zinc » Sun Apr 29, 2012 6:40 pm
Paul;
Well done for keeping your promise and delivering this magnificent piece of work. As always quality. :D
Adendum
Post by Adendum » Sun Apr 29, 2012 7:23 pm
pewe wrote:Thanks.
Looks interesting.
Just the simple "Go Menu" in WWB.
pewe
Post by pewe » Sun Apr 29, 2012 7:53 pm
Thanks Adendum.
For some reason I didn't have that - but I have now.
Thanks again.
jordan
Post by jordan » Tue May 01, 2012 1:23 am
impressive slideshow extension Paul
I see you have removed the Camera Slideshow.xwb … oeps accident . :wink: . was about to mail you
+TNX for you index update mail . cheers!
Adendum
Post by Adendum » Tue May 01, 2012 11:52 am
jordan wrote:impressive slideshow extension Paul
Oops indeed. I must have dragged the .xwb file into the zip file at some stage. I've removed it now. But those that have it are welcome - if anyone wants the 3 xsl files that go with it just let me know.
gp2727
Post by gp2727 » Wed May 02, 2012 1:59 am
Adendum wrote:If anyone wants the 3 xsl files that go with it just let me know.
Very Nice Extension... I'll take you up on the offer for the 3 xsl files too...Thanks in Advance.
stamjoe
Post by stamjoe » Wed May 02, 2012 8:19 am
Thanks Adendum.
NIce work!
cheers!
Joe
infos
Post by infos » Mon May 07, 2012 9:55 pm
thanks, but thanx, does not work for me this extension...I've tried in different web browsers and I've got nothing to be displayed on the page..NADA!
Adendum
Post by Adendum » Mon May 07, 2012 10:34 pm
infos,
Well if you want some help with it you'll have to provide just a little bit more information old chap. Might be a good start if you read the help file too.
infos
Post by infos » Tue May 08, 2012 11:42 am
well, now it works...I had to add an extra code.
thanks again for your nice script.
cheers,
infos
Adendum wrote:infos,
Adendum
Post by Adendum » Tue May 08, 2012 12:01 pm
infos wrote:well, now it works...I had to add an extra code.
cheers,
infos
Add code? The extension doesn't require you to add anything other than complete the relevent properties. So I assume you mean that you had NOT entered some values in one or more of the properties. I'm not splitting hairs but it's important for other readers of this thread to not get the impression that they need to 'add code'.....that would defeat th whole point of extensions.
infos
Post by infos » Tue May 08, 2012 1:07 pm
yes, I added this:
jQuery(function(){
jQuery('#camera_wrap_1').camera({
</script>
your extension does not generate automatically this piece of code which is needed in order to work correctly
cheers,
infos
Adendum
Post by Adendum » Tue May 08, 2012 1:35 pm
I beg to differ. And may I add I am not that dumb to release an extension that didn't use key code to make it work.
There is an xsl file used in the extension specifically to cater for different conditions:-
<?xml version="1.0" encoding="UTF-8"?>
<xsl:stylesheet xmlns:xsl="http://www.w3.org/1999/XSL/Transform" version="1.0">
<xsl:template match='/'>
<xsl:for-each select="DATASET/ITEM">
<!-- Normal -->
<xsl:if test="SELECTASIZE = 'Normal'"> <!-- write html for Normal size -->
<style type="text/css">
.fluid_container {margin: 0 auto;}
$iframestyles$
</style>
jQuery(function(){
</script>
</xsl:if>
<!-- Fullscreen -->
<xsl:if test="SELECTASIZE = 'Fullscreen'"> <!-- write html for Fullscreen -->
        <xsl:choose>
             <xsl:when test="CAPTIONSORTHUMBS = 'Captions'"> <!-- write for captions -->
.fluid_container {bottom: 0;left: 0;position: fixed;right: 0;top: 0;z-index: 0;}
#camera_wrap_1 {bottom: 0;left: 0;margin-bottom: 0!important;position: fixed;right: 0;top: 0;}
$iframestyles$
</style>
jQuery(function(){
     height: 'auto'
</script>
             </xsl:when>
        <xsl:otherwise> <!-- write for thumbs -->
.camera_thumbs {margin-top: -100px;position: relative;z-index: 1;}
<xsl:text disable-output-escaping="yes">.camera_caption > div {display:none;}</xsl:text>
$iframestyles$
</style>
jQuery(function(){
     height: 'auto'
</script>
        </xsl:otherwise>
    </xsl:choose>
</xsl:if>
</xsl:for-each>
</xsl:template>
</xsl:stylesheet>
So if you select Normal or Fullsize you get different code.
Therefore in what circumstances did you have to manually add this code? I would like to see your project file (just that page) to identify what you did that caused the extension not to write the correct code.
