jordan
Post
by jordan » Sun May 31, 2015 7:54 pm
jaybird wrote:Hi,
Downloaded today your jor_carouselManipulation_update9b RAR File (.rar) and tried to manually install in WB 10 and the file is not recognized ?
Thanks,
Jay
hi jaybird,
please try this recompiled EB5.2 version -
jor_carouselManipulation EB5.2
hope this helps!
jordan
Post
by jordan » Mon Sep 21, 2015 3:21 pm
jor_carouselManipulation update 10 - SOON - CRAZY CHICKEN UPDATE!
update 10 summary:
- animate into position - NOW with CSS3 animation - included animates.css library or use WB CSS3 animation
- new option - auto switch - only engage autoplay if the carousel is in view - (vertical axis)
- many powerful enhancements for thin film mode
- many fixes and enhances for RWD design compatibility
- other ...
see a preview in the new cool demo on jorextennsions.com - section jor_INSPIREREYS - (around the globe-destination)
NOTE: jor_carouselManipulation 10.0 is WB10+ only!
tommy888
Post
by tommy888 » Mon Sep 21, 2015 5:07 pm
Looking forward to it JOR! Thanks
jordan
Post
by jordan » Fri Sep 25, 2015 2:28 pm
jor_carouselManipulation10.0 SUSPEND!
I run into a design fault in JMPv3.0 b5.6 therefore b5.6 has been removed
this fault also involves jor_carouselManipulation 10.0 which is not yet released . pfef:)
both will be released later!
@ tommy888 - will release as soon as possible, TNX for the thumbs .
tommy888
Post
by tommy888 » Fri Sep 25, 2015 6:15 pm
Ok, Jor Thnaks
jordan
Post
by jordan » Wed Oct 07, 2015 12:45 pm
jor_carouselManipulation update 10 - CRAZY CHICKEN UPDATE!
01. added : added option - corner radius for jQuery slider and progressbar
02. fix/enhanced : thin film mode - abide RWD design (visibility) - (rewrite)
03. changed : thin film mode - option "position | index" removed - (z-index is now set as the carousel resides)
04. enhanced : thin film mode - added option - top position (auto/manual) - RWD enhancement
05. added : thin film mode - added option - FRAME: border/background size/shadow
06. added : thin film mode - added option - BLOCK: background image/size/shadow
07. new : thin film mode - new option - block cover opacity switch (first/last slide)
08. new : thin film mode - smart object animation - only animate if object is not in view
09. enhanced : callback before now also executes at carousel init.
10. fix : jQuery slider vs carousel effects mode fix
11. fix : object animation abide RWD design - (rewrite)
12. new : object animation now also include CSS3 animation - (included animate.css library)
13. new : object animation - CSS3 animation - also target by class
14. new : object animation - new option - create custom CSS3 keyframe animation (advanced)
15. new : new option - auto switch - only engage autoplay if the carousel is in view (vertical axis)
16. new : full width pseudo fix - new option - kill overlap (remove overlap)
17. new : full width pseudo fix - new option - staticX (counter horizontal scrollbar)
18. changed : compiled with EB5.2 - (WB10+ only)
19. additional : other internal improvements
20. additional : updated jor_carouselManipulation_easystart.wbs project
for full update history, demo and download see top post
LTH
Post
by LTH » Sun May 01, 2016 12:11 am
jordan I might be mistaken but a year or so ago when I downloaded this great extension I thought I was able to access the demo pages you have referenced in your help file. Can you point me in the right direction to find these again?
jordan
Post
by jordan » Sun May 01, 2016 3:31 pm
LTH wrote:jordan I might be mistaken but a year or so ago when I downloaded this great extension I thought I was able to access the demo pages you have referenced in your help file. Can you point me in the right direction to find these again?
hello LTH,
the demos are in the download - in the folder -
LTH
Post
by LTH » Sun May 01, 2016 6:37 pm
Not sure why but all that's in mine is 4 jpg images. I downloaded it again and just unzipped it and it's the same thing 4 jpg files. Let me know if there's any other way to get these. Thx
jordan
Post
by jordan » Sun May 01, 2016 10:17 pm
you do not have a -
jor_carouselManipulation_easystart.wbs - inside the (first) folder ?:\
I just viewed the download, it's in the folder for me ?
try this download, it's the same but I only included the .wbs -
jor_carouselManipulationLTH
electrochrisso
Post
by electrochrisso » Mon May 02, 2016 12:28 am
I just downloaded the file and everything seems to be there, the size of the rar is 455,250 bytes.
LTH
Post
by LTH » Mon May 02, 2016 1:31 am
Here's what I get when I try to open any link.
jordan
Post
by jordan » Mon May 02, 2016 10:49 am
LTH wrote:Here's what I get when I try to open any link.
hi LTH,
enable -
preview entire website - in WB
@electrochrisso - tnx for taking the time, feedback always appreciated .
LTH
Post
by LTH » Mon May 02, 2016 12:44 pm
I must have gone brain dead.
I knew this but it absolutely slipped my mind. Thx jordan
