jor_tabManipulation 5.0
protectourlands
Re: jor_tabManipulation_update 4
Post by protectourlands » Fri Nov 08, 2013 1:21 pm
Hi Jordan
Published a test page and it worked fine. It's only in the quick preview that the padding doesn't show. No worries. Thank you.
jordan
Post by jordan » Fri Nov 08, 2013 4:58 pm
hi cover_data,
if it isn't in the extension and can't/won't be added then it simply becomes custom coding
I'm sorry but I can't help you with that, custom coding can take up much time
looking at your example code does not give me any idea of what you trying to achieve
that alone would take time, then the coding itself ?
unless you have a clear idea, clear code then no sorry, I can't help you with that
jordan
Post by jordan » Fri Nov 08, 2013 4:59 pm
protectourlands wrote:Hi Jordan
ah, o.k very good, glad to know it works!:)
jordan
Re: jor_tabManipulation_update 5
Post by jordan » Mon Oct 20, 2014 11:16 am
jor_tabManipulation update 5
jor_tabManipulation update 5 is a rewrite of jor_tabManipulation ... now the ultimate single style jQuery Tabs manipulator!:)
01. new: select any of the 24 default themes by a single property
02. new: option corner radius
03. new: option external control trace mouse behavior
04. enhanced: option disable theme instance
05. enhanced: added color mode properties (not used/used/transparent)
see a cool new demo for jor_tabManipulation at - visit jorextensions.com
for full update history, demo and download see top post
protectourlands
Re: jor_tabManipulation_update 5 **NEW**
Post by protectourlands » Mon Oct 20, 2014 3:00 pm
You've done it again Jordan. Thank you for making this available. I use all your manipulation extensions. They are fantastic!
jordan
Post by jordan » Mon Oct 20, 2014 4:13 pm
hehe:), always nice to hear protectourlands, hope you create something great with them:)
