Ultimate Page Scroller - Extension ***No longer supported***
supersonictt
Re: Ultimate Page Scroller - Extension Updated ***26/03/2012
Post by supersonictt » Fri Mar 30, 2012 11:56 pm
Hello SUB, Thanks a lot for the reply.
Actually I tried it but am still struggling :shock: it is time for bed now so I will try it out tomorrow :)
Thanks a lot for being there :)
supersonictt
Post by supersonictt » Mon Apr 02, 2012 11:15 pm
SUB wrote:Hi TT! yes thats correct, you can achieve this effect with custom timed events and the page scroller. There is obviously some kind of delay effect for this too!
Cheers,
Scott
Hello SUB,
I believe that there is something with the pixels scrolled, right?
I mean, once you click other menu item, the current text disappears and when it scrolls up or down to the new item, the text fades in after a delay.
Is it possible to provide a simple example in WWB? If you are free for that of course :)
I searched google for that thing but can't seem to search for the right words!
Thanks a lot.
Post by zinc » Sat Apr 14, 2012 3:31 pm
Hey Scott any news/updates on the issue with iPhone and anchors?
madebyibloo
Post by madebyibloo » Sat Apr 14, 2012 4:48 pm
bendigo wrote:Hey Scott any news/updates on the issue with iPhone and anchors?
Hi B! not had chance to look yet B, i've read that the scrollto plugin is fragile with portable devices so I think the way to go about it is to use the .animate function within jquery, ill keep you posted B :)
Cheers,
Scott
Cheers,
Scott
Post by zinc » Mon May 21, 2012 7:26 am
Webbuilder8.1 wrote:Does anyone know if this works with a layer?
Use this
viewtopic.php?f=42&t=45904
madebyibloo
Post by madebyibloo » Wed May 30, 2012 11:36 am
cp.abel.leon wrote:Hi Sub,
How can I use this extension horizontally and view centered, like this http://www.dienso.com
I can do it for one resolution for example 1600 x 900, but it's not rigth for any other resolution.
Thanks for advance.
(sorry for my english :oops: )
Hi, i'm not sure this can be done easily without any custom coding, its standard html. With it being horizontal, browsers read it just like as if it would be vertical (starting from the top of page but in this case, staring from the very left hand side).
Cheers,
Scott
Cheers,
Scott
madebyibloo
Post by madebyibloo » Wed Jun 27, 2012 4:52 pm
IeMS wrote:Sub @ ibloo - If this question has already been asked forgive me as there are 9 pages of comments to read through. I am curious if this works with all resolutions? IE - the resolution on my computer is 1600x900 widescreen. Should I set the paginate to horizontal, and someone with a 19" or even 17" screen views the website, will the bookparks be off? Or is that the purpose of this extension - to avoid this possible issue? Just curious. Thank you for your time.
I love your wesite btw. Very cool.
Hi Rob! Thanks for your kind words!
My personal opinion on what your requiring is this...
I would create your layout with a width area of 1920px..
Basically like this:
1) Page width (in properties): 7680 (this will cater for 4 pages)
2) Place the first bookmark at the far top-left hand side, then go across the width to 1920 and place another bookmark and so on
3) Basically what this will do is, users who have a resolution of 1920x1080 on a large monitor will not see the content on screen from the second page/second bookmark
4) Always aim to build the page content with around 970px width (place a shape object with 970px at the top point of your bookmaks so you know your workspace)
5) and...dont forget to set the overflow-x to hidden in the page properties under misc to give it that x-factor ;)
ps. yes set the direction to: horizontal in the UPS extension properties.
Hope this helps,
Cheers,
Scott
Cheers,
Scott
madebyibloo
Post by madebyibloo » Thu Jun 28, 2012 1:41 pm
IeMS wrote:Scott,
Thank you for this information. I will give it a try. Can you tell me what the visitor experience will be if they have a more narrow screen - like a 19" or 17"? Smaller resolution?
Also, what are you recommendations for vertical scrolling?
Building sites at 970 width (centered) is the first thing that I learned using this software. That is what my site is set to and it fits nicely in smartphones (landscape).
"and...dont forget to set the overflow-x to hidden in the page properties under misc to give it that x-factor" - what does this do?
Thank you again.
Hi Rob,
There will be no difference really in what resolution the user uses, the only difference would be the amount of time it scrolls but if you set it pretty quick, lets say 800 all should be fine.
you're spot on with the 970px ;)
The overflow-x set to hidden - this will make the scrollbars across the bottom (of a horizontal scrolling website) dissapear, giving a more pro aproach to this style of website.
As for a vertical scrolling website - This is standard procedure really, it just depends on your style/taste, i would normally keep a work area content of around 500px-600px vertically.
Hope this helps,
Cheers,
Scott
Cheers,
Scott
tsunamitommy
Post by tsunamitommy » Mon Aug 13, 2012 1:21 pm
I was wondering how to use this extension without having horizontal scroll bars in the browser. Thanks
Tom Novick - Owner
Lionshead Designs
Custom Web and Graphic Design
http://www.lionsheaddesigns.com
madebyibloo
Post by madebyibloo » Mon Aug 13, 2012 1:38 pm
tsunamitommy wrote:I was wondering how to use this extension without having horizontal scroll bars in the browser. Thanks
Read the post above
Cheers,
Scott
Cheers,
Scott
naftalina
Post by naftalina » Fri Jun 21, 2013 6:16 pm
Won't work in version 9!?
... or i did something wrong here! :?
When i add extension in the project, then links to bookmarks don't working at all?! :(
madebyibloo
Post by madebyibloo » Fri Jun 21, 2013 9:56 pm
naftalina wrote:Won't work in version 9!?
Hi, I've not installed v9 yet (I cant believe it either, purchased on launch, been too busy)....
I'll try it and let you know...
Cheers,
Scott
Cheers,
Scott
naftalina
Post by naftalina » Fri Jun 21, 2013 10:41 pm
Cheers,
Scott
When I set jquery to 1.7.2 than working!
Now I set jquery to 1.9.1 and still working.
So, it's very possible that i did something wrong.
Thanks, Scott, for this extension and feedback :)
madebyibloo
Post by madebyibloo » Tue Jun 25, 2013 2:32 pm
Update in the next couple of days :)
Cheers,
Scott
Cheers,
Scott
madebyibloo
Re: Ultimate Page Scroller - Extension Updated ***27/06/2013
Post by madebyibloo » Thu Jun 27, 2013 8:33 am
Updated, please read original post on page 1.
Cheers,
Scott
Cheers,
Scott
