Supersized Slideshow (Updated 17/3/2011)
smartmedia
Post by smartmedia » Sun Mar 13, 2011 6:37 am
Version 1.0.0.1
Build with 2.6.0 Extension builder
Making extension is a nice hobby but takes time, any body who has build at least one knows that. Consider to donate some money for coffees in paypal at smartmediagr@gmail.com
More about
http://buildinternet.com/project/supersized/
Updates:
nav-bg.png added as embedded as forgotten in initial version.
The extension is available via Extension Download manager under the name Supersized Slide Show.
infogate
Re: Supersized Fullscreen Background Slideshow (Working)
Post by zinc » Sun Mar 13, 2011 7:21 am
Hey Man;
I know the feeling but but usually BF comes to my rescue. I have built this one for my own website and use it but never released it. You are doing a great job.
Good news everyone!
stamjoe
Post by stamjoe » Mon Mar 14, 2011 12:56 pm
Hey Chris, good morning,
thanks for your consideration about this extension.
Keep up.
Joe
smartmedia
Post by smartmedia » Mon Mar 14, 2011 5:47 pm
Hi..
I am facing some problems on how i will add the images in Galley because the images are included inside Javascript array. Question: Do i need to use xsl..??? Any help appreciated.
infogate
Post by BaconFries » Mon Mar 14, 2011 6:52 pm
Yer it be best to write a xsl for this I did help bendigo with this, but for the life of me I cant find the xsl file and it would take me a bit of time to rewrite and test hpefull he will see this and he might still have a copy of the xsl file you can use...
Ok update on this I have looked at the js and to call the images you would need a xsl that be similar to this
In the code do this
$images$
{image : "$lastimage$", title : "$title$, url : "$url$"} <<< this is the last image and doest need a ,
Then build a xsl using code below pointing it to $images$ this will insert all the other images,titles and urls if you notice each one ends with a , but the last image that is why I an suggeting you write as I have described
<?xml version="1.0" encoding="UTF-8"?>
<xsl:stylesheet xmlns:xsl="http://www.w3.org/1999/XSL/Transform" version="1.0">
<xsl:template match='/'>
<xsl:for-each select="GALLERY/IMAGE">
<xsl:text>[ { image:"</xsl:text>
<xsl:value-of select="FILENAME"/>
<xsl:text>",</xsl:text>
<xsl:text>title :"</xsl:text>
<xsl:value-of select="TITLE"/>
<xsl:text>","</xsl:text>
<xsl:text>url :</xsl:text>
<xsl:value-of select="URL"/>
<xsl:text>" },]
</xsl:text>
</xsl:for-each>
</xsl:template>
</xsl:stylesheet>
Post by zinc » Mon Mar 14, 2011 7:20 pm
Yes BF Did write me a new XSL
<?xml version="1.0" encoding="UTF-8" ?>
<xsl:output method="html" />
<xsl:template match="/">
<a href="{URL}"><img src="{FILENAME}" title="{TITLE}" /></a>
</xsl:for-each>
</xsl:template>
</xsl:stylesheet>
Good news everyone!
Post by BaconFries » Mon Mar 14, 2011 7:23 pm
Looking at the new code I think it draws the image into the script in a different way now bendigo, if you still have all the original files can you email them at the usual address were I can compare yours to the new ones and check for differences...I have went through old emails but cant find anything....
Post by zinc » Mon Mar 14, 2011 7:31 pm
BaconFries wrote:Looking at the new code I think it draws the image into the script in a different way now bendigo, if you still have all the original files can you email them at the usual address were I can compare yours to the new ones and check for differences...I have went through old emails but cant find anything....
on its way to you now mate....
Good news everyone!
smartmedia
Post by smartmedia » Mon Mar 14, 2011 7:56 pm
Hi..
Now i get it some how, how is working. I change a little the FB code in order to work.
<xsl:text>{image: '</xsl:text>
<xsl:text>', title:'</xsl:text>
<xsl:text>', url:'</xsl:text>
<xsl:text>' },
</xsl:text>
</xsl:for-each>
</xsl:template>
</xsl:stylesheet>
Thanks both of you.
infogate
smartmedia
Re: Supersized Slideshow (Released 16/3/2011)
Post by smartmedia » Wed Mar 16, 2011 9:40 pm
infogate
stamjoe
Re: Supersized Slideshow (Updated 17/3/2011)
Post by stamjoe » Thu Mar 17, 2011 3:04 pm
Chris are u the best man.
Thanks very much for this.
Keep up.
Joe
stamjoe
Post by stamjoe » Thu Mar 17, 2011 3:10 pm
I just test it. Works fine.
Question 1. how can i disable the bottom photos if i want to use it only with the original background photos?
Question 2. Which is the suggested picture size for 1024X768 monitors?
Thanks again.
Joe
me.prosenjeet
Post by me.prosenjeet » Thu May 19, 2011 3:29 am
Somehow this doesnt seem to work for me.
Added two images, kept the variables to default....I see a black screen with the default footer...no images.
Any help!
Ok, it works on FF but not in IE8
http://lucknowwebs.com/1087_test
www.Lucknowwebs.com
Post by zinc » Sun Feb 12, 2012 9:23 am
SM please can update your extension with the latest version
Of this slideshow as it is awesome!
Good news everyone!
