Sliding Panel Photo Wall Gallery (Released 12/3/2011)
smartmedia
Post by smartmedia » Fri Mar 11, 2011 4:55 pm
Version 1.0.0.0
Build with 2.6.0 Extension builder
More info about the Gallery:
http://tympanus.net/codrops/2010/05/14/ ... th-jquery/
Properties
Futures
Added ability to include image as background to thumb list ( if no image, color will show up )
Added ability to include image as background to image view panel ( if no image, color will show up )
Added ability to change back & next buttons with transparent image. ( Included some, otherwise make your own )
Thumbnails are generated automatically ( You can change the width - height - folder name - prefix or thumbs )
Since this Gallery is fully paged Return link added to return back to your page, also you can change the text.
You can change the color of info bar according your needs.
Download
http://dl.dropbox.com/u/8766047/Sliding ... allery.rar
infogate
Re: Sliding Panel Photo Wall Gallery (Working)
Post by BaconFries » Fri Mar 11, 2011 6:04 pm
This is untested but it should work as I have used in similar extensions, when using the xsl in the builder please use Type:Gallery make the Variable: $images$ and insert as shown below in the HTML you will also need to make Varibles for the Height and Width and you will just use one Image for both the Thumbnail and Large... as mentioned I havnt tested this for the script you need the xsl for but it should work...
The HTML
<div id="thumbsWrapper">
<div id="content" >
$images$
<div class="placeholder"></div>
</div>
The XSL
<?xml version="1.0" encoding="UTF-8"?>
<xsl:stylesheet xmlns:xsl="http://www.w3.org/1999/XSL/Transform" version="1.0">
<xsl:output method="html"/>
<xsl:template match='/'>
<xsl:for-each select="GALLERY/IMAGE">
<img src="{FILENAME}" height="{HEIGHT}" width="{WIDTH}" alt="{FILENAME}" title="{TITLE}" /></a>
</xsl:for-each>
</xsl:template>
</xsl:stylesheet>
smartmedia
Post by smartmedia » Fri Mar 11, 2011 8:57 pm
Thanks man, i did it with small changes.
<img src="{THUMB}" width="{THUMB_WIDTH}" height="{THUMB_HEIGHT}" alt="{FILENAME}" title="{TITLE}" />
infogate
protectourlands
Post by protectourlands » Fri Mar 11, 2011 11:17 pm
Looking forward to this one.
smartmedia
Post by smartmedia » Sat Mar 12, 2011 10:51 am
Hi..
BF, do you know how i will center the thumbs in page, right now start from left and because the user can change the width and height of thumbs doesn't look so good, they leave some space empty in right.
infogate
Post by BaconFries » Sat Mar 12, 2011 2:41 pm
I would need to take a look at the css it will probably be something in there...or maybe try this
<img src="{THUMB}" width="{THUMB_WIDTH}px" height="{THUMB_HEIGHT}" px alt="{FILENAME}" title="{TITLE}" />
or
<img src="{THUMB}" width="100%" height="100%" alt="{FILENAME}" title="{TITLE}" />
smartmedia
Post by smartmedia » Sat Mar 12, 2011 3:55 pm
Thanks BF, i found the solution.
I just put text-align:center; in #content img class and it's done.
infogate
CJS
Post by CJS » Sat Mar 12, 2011 8:01 pm
smartmedia,
This will make a great addition to the WB extension library. I look forward making use of your good work.
Thanks.
smartmedia
Re: Sliding Panel Photo Wall Gallery (Released 12/3/2011)
Post by smartmedia » Sun Mar 13, 2011 6:45 am
Extension is released. Download and enjoy it.
infogate
smartmedia
Post by smartmedia » Sun Mar 13, 2011 10:43 am
Well,
In order to show a different image set for back and next, you must create it with a program like this:
Those are the file are used embedded and they are image set, width must be 40px and height 80px. So, both back & next images are 1 file. I hope you understand.
Personally i use RealDraw 5.
infogate
smartmedia
Post by smartmedia » Sun Mar 13, 2011 11:36 am
Please, re download the extension, i have included some nav icons for back and next images.
infogate
amrajadhyaksha
Post by amrajadhyaksha » Tue Mar 15, 2011 3:32 am
Good work as always.
My request is about a good accordion. Codrops has a few of these, eg:
http://tympanus.net/Tutorials/ElegantAccordion/
http://www.armagost.com/zaccordion/
WWB has an accordion but it has size restrictions. Would be great to have a full page or at least full legth one.
Thanks, in anticipation.
And oh yes, thanks again for the zooms.
stamjoe
Post by stamjoe » Thu Mar 17, 2011 4:00 pm
Perfect Chris.
Joe
me.prosenjeet
Post by me.prosenjeet » Sun Mar 18, 2012 4:52 pm
Was trying this gallery. Seems Super!
However, one issue. After adding the images, moment I save the project, the default navigation buttons change and point to another image*. I tried selecting the buttons that come with this extension and save again but still when I reopen the project, the image set is gone and another image* is set as button.
Any idea?
www.Lucknowwebs.com
