jQuery Cycle Slideshow ***26/09/12***
Post by BaconFries » Tue Mar 01, 2011 9:15 am
****Updated****
New features added
Cycle Slideshow Redirect
Image redirect allows a url to be selected and on the last image it will open the selected url used.
Cycle Slideshow Pager Display
Allows a pager navigation to be added over the images
Cycle Slideshow Pager Event
Allows you to be able to either select the image by either hovering over the pager number on by using click to navigate the images.
Cycle Slideshow Pager CSS
Allows you to set the pager background color, active color, padding,pager position on image top, bottom, left, right,z-index position etc.
Meets W3C Standards
Built with Extension Builder 3.0.1
jQuery Cycle Plugin is a simple slideshow that allows you to add images to your page with a fadein/fadeout effect and can be set to stop at the last image displayed.
Download Extension via the Extension Manager
Re: jQuery Cycle Slideshow ***01/03/11***
Post by BaconFries » Tue Mar 01, 2011 9:23 am
smartmedia
Post by smartmedia » Tue Mar 01, 2011 9:59 am
Thanks, very nice, how exactly the jquery is working to disable or enable..???
Because i like to use it also in my extensions...
infogate
Post by BaconFries » Tue Mar 01, 2011 10:15 am
Yes it is possible, but the way I have written the extension as of now only displays images without the <a href " "> tag to use links...personally I dont see the need for <a href " "> as it is ment to display images on a page and not for navigating away from your page/site the only other need is if you require it to open in another window/browser window to view a larger image..
stamjoe
Post by stamjoe » Tue Mar 01, 2011 11:12 am
Thanks man.
Joe
Reptilicious
Post by Reptilicious » Tue Mar 01, 2011 11:23 am
Thanks! Is it better if the images have the same size?
Post by BaconFries » Tue Mar 01, 2011 1:02 pm
***Updated 01/03/11***
Added Width, Height, URL/Link to the extension.
Post by BaconFries » Wed Aug 24, 2011 8:32 am
The "Extension" is only available to download from the "Extension Manager" you can grab it by going to Tools>Extension Manager>Galleries
Re: jQuery Cycle Slideshow ***10/05/12***
Post by BaconFries » Thu May 10, 2012 10:09 pm
Updated jQuery Cycle Slideshow ***10/05/12***
Re: jQuery Cycle Slideshow ***26/09/12***
Post by BaconFries » Wed Sep 26, 2012 2:02 pm
****Updated****
Post by zinc » Fri Jan 04, 2013 11:09 am
BaconFries wrote:****Updated****
Hi BF;
Can you tell me if your extension covers all the SFX or is it just Fade.
B
Good news everyone!
Post by BaconFries » Fri Jan 04, 2013 11:48 am
You can select from any of the 27 sfx effects to none or have them all displayed by selecting from Cycle Slideshow effects dropdown list in the extension properties
Post by zinc » Fri Jan 04, 2013 12:08 pm
BaconFries wrote:You can select from any of the 27 sfx effects to none or have them all displayed by selecting from Cycle Slideshow effects dropdown list in the extension properties
Thanks B a great and under-rated extension!!! I love it!!!!
Good news everyone!
