Beautiful Background Image Navigation (Updated 1/3/2011)
smartmedia
Re: Beautiful Background Image Navigation (Updated)
Post by smartmedia » Tue Mar 01, 2011 3:28 pm
Hi..
If the export worked that means is something wrong with the pictures you using. Check the names to be without spaces, i don't know anything more that may cause malfunction. Also try to update into the new version 1.4.0.0
infogate
Re: Beautiful Background Image Navigation (Updated 1/3/2011)
Post by BaconFries » Tue Mar 01, 2011 3:48 pm
When using images or any files please do not use names with spaces, special characters, uppercase lettering... also only use file extensions with lowercase lettering :example jpg not JPG
Incorrect
images/Pumi_216%542.JPG
images/Pyth_057 542 Black.jpg
images/Caro_199 542.jpg
Correct
images/pumi_216542.jpg
images/pyth_057542 Black.jpg
images/caro_199542.jpg
Reptilicious
Post by Reptilicious » Wed Mar 02, 2011 11:04 am
Updated the extention, changed the names and it works! :)
Thank you very much for your help!! :D :D
stamjoe
Post by stamjoe » Wed Mar 02, 2011 3:30 pm
Wow man. Its awesome. I will give it a try.
Thanks.
Joe
stamjoe
Post by stamjoe » Wed Mar 02, 2011 4:03 pm
Chris its only works with 3 pieces? If i need to put 5?
Tahnks
Joe
smartmedia
Post by smartmedia » Wed Mar 02, 2011 4:22 pm
Φίλε μου, αυτό το scriptaki γράφτηκε για 3 φωτογραφίες, δεν είναι δικό μου... Μάλλον θα πρέπει να αρκεστείς σε αυτό..
infogate
stamjoe
Post by stamjoe » Wed Mar 02, 2011 4:30 pm
Euxaristo poly.
Etoimazeis kai alla wraia scripts?
Joe
Patr100
Post by Patr100 » Thu Mar 17, 2011 1:15 pm
I downloaded this ages ago and now when I find I wanted to integrate it into WB there is no wbx file, nor any notes (which you refer to) in the download you provided just some css , images etc to show an example.
So how is this a proper WB extension and how do I integrate it into WB? Something is missing.
Also the auto import does not recognise rar files only zips (I know they are both compressed formats but WB sees them as different.
smartmedia
Post by smartmedia » Thu Mar 17, 2011 2:22 pm
Hi..
If you have download the rar file, just extract it in a folder, then select Extension Manager from menu.
When the window opens, select manual install and choose the extension from the folder you have extracted. In properties window of the extension on every option are given enough information to understand how is working.
infogate
Patr100
Post by Patr100 » Thu Mar 17, 2011 2:52 pm
smartmedia wrote:Hi..
But I already tried that - as I said , there is no extension ie wbx file in the download at all so how can I "chose the extension" when it isn't there!
smartmedia
Post by smartmedia » Thu Mar 17, 2011 3:45 pm
Hi..
I download it 1 hour a go when i read your post and the file was inside. Please re-download it again and try... I don't have any other reports from others, perhaps something went wrong when you download it the first time.
infogate
amrajadhyaksha
Post by amrajadhyaksha » Wed Sep 28, 2011 7:54 pm
There is an even more attractive first cousin of this menu, on the same site, I am sure you must have seen it.
http://tympanus.net/Development/Sliding ... mple9.html
All the best, in anticipation.
me.prosenjeet
Post by me.prosenjeet » Thu Apr 05, 2012 12:53 pm
hinkey wrote:Hi there,
it seems that the download link ist broken.. get a NOT FOUND message
Thks Hajo
Download link is working fine
www.Lucknowwebs.com
Post by BaconFries » Fri Aug 09, 2013 11:17 am
Please read my reply to.you at thr follow
viewtopic.php?f=29&t=57414
