Bottom Slide Out Menu 1.6 (Updated 25/2/2011)
smartmedia
Post by smartmedia » Sun Feb 20, 2011 9:29 am
Version 1.6
Build with 2.6.0 Extension builder
Support UTF-8 characters
Document type: HTML 4.01 Transitional
Info:
http://tympanus.net/codrops/2010/03/09/ ... th-jquery/
Properties image
Download updated version
http://dl.dropbox.com/u/8766047/FreshBo ... utMenu.rar
Unicode version
http://dl.dropbox.com/u/8766047/FreshBo ... nicode.rar
infogate
Re: Bottom Slide Out Menu
Post by BaconFries » Sun Feb 20, 2011 1:14 pm
You can try adding ... <a href="#"> replacing # with the url
What the code looks like before
  <li>
<a>
<i class="icon_about"></i>
<span class="title">About</span>
<span class="description">Learn about us and our services</span>
</a>
</li>
And after adding the href reference <a href="#"> replacing # with the url
<li>
<a href="#">
</a>
</li>
smartmedia
Post by smartmedia » Sun Feb 20, 2011 5:17 pm
Hi..
I tried your example but everything messed up, i don't know why. I removed and everything was ok. Any ideas...???
infogate
Post by BaconFries » Sun Feb 20, 2011 6:20 pm
Ok I cant say what you might have done, but I have uploaded a demo to show it working with the code I gave you to try. I f you can give a url I will take a look at it and se what may be wrong and let you know how to fix if I can...
Demo site
http://justtesting123.comuf.com/menudemo/index.html
smartmedia
Post by smartmedia » Sun Feb 20, 2011 6:40 pm
Hi..
Sorry, it was my mistake, i used double <a> tag instead of 1 like this:
<li>
<a>
<a href="#">
</a>
</li>
I fixed, perhaps can you help me on how i will remove the underline in links..??? Mary Lou in response says:
Hi Tom, the href has to be put into the link element: <a href=”…
You probably mean the underline. That you remove by specifying in the CSS under ul#menu a outline and text-decoration:none. Hope it helps, ML
what exactly i must change...???
infogate
Post by BaconFries » Sun Feb 20, 2011 6:46 pm
Hmm then this will need to be modified in the css file.....
Before
ul#menu a
    cursor:pointer;
    position:relative;
    float:left;
    bottom:-95px;
    line-height:20px;
    width:210px;
After
ul#menu a{
    cursor:pointer;
    position:relative;
    float:left;
    bottom:-95px;
    line-height:20px;
    width:210px;
    text-decoration:none;
smartmedia
Post by smartmedia » Sun Feb 20, 2011 7:02 pm
Thanks BF,
Fixed,
One last issue, in some other extension i shaw that when you draw the extension you are actual see it, i have select Live HTML redering but i see only the text. Do i need to add something in Render HTML section...???
infogate
Post by BaconFries » Sun Feb 20, 2011 7:26 pm
Yes this is correct since it is only text that is getting displayed in live rendering as no images are displayed until you use the mouseover effect then the image appears...if I was building this then I would simply take a screen shot of the menu with one on the images open then use display image this will allow the user to be able to judge the position of the extension on there page...
smartmedia
Re: Bottom Slide Out Menu 1.2 (Updated)
Post by smartmedia » Mon Feb 21, 2011 9:33 am
Hi..
Extension has been updated. Please download again..
infogate
Reptilicious
Post by Reptilicious » Fri Feb 25, 2011 12:12 pm
Thanks for this nice menu!
Could you make it possible to change the background color of the menu?
smartmedia
Post by smartmedia » Fri Feb 25, 2011 4:29 pm
Reptilicious wrote:Thanks for this nice menu!
Please download again. Check the new properties..
infogate
Reptilicious
Post by Reptilicious » Fri Feb 25, 2011 5:46 pm
Thanks!!! :D :D :D
Reptilicious
Re: Bottom Slide Out Menu 1.6 (Updated 25/2/2011)
Post by Reptilicious » Mon Dec 23, 2013 3:52 pm
Is someone able to add 2 (or at least 1) more menu to this extension? This would be very much appreciated!
Reptilicious
Post by Reptilicious » Wed Jan 08, 2014 10:55 am
Reptilicious wrote:Is someone able to add 2 (or at least 1) more menu to this extension? This would be very much appreciated!
Can some please take a look at this, to see if this possible? To add 2 more menu's to this extension?
Post by BaconFries » Wed Jan 08, 2014 1:32 pm
Please try not to repeat asking the same question over and over. Only the original builder can assist with this, and as he is no longer active then this may not happen. To do what you are asking would require a total rebuild of the extension, so it not something that can just be done in minutes or a couple of hours it is going to take sometime and only if another builder is intrested in doing so.
