Highslide Single Image Update***08/08/10***
Post by BaconFries » Sat Jun 05, 2010 12:03 pm
Highslide Single Image ***08/08/10***
Highslide JS by Torstein Hønsi
http://highslide.com/
What is Highslide Single Image JS?
Highslide JS is an single image, viewer written in JavaScript.it works in a similar fashion to the Highslide Mini Gallery except that it allows you to place multiple single images on your webpages without the need of a gallery driven menu.
***Update*** I have included a extra option in the properties to allow the addition of a caption or a description of the image the update version can be downloaded from below along with the previous version without the caption property.
User terms of use Note if using for a Commerial Site then you need to purchase a licence to use.please visit the highslide site for further datails on costs.
Version: 4.1.8 (October 27 2009)
Config: default
Author: Torstein Hønsi
Support: http://highslide.com/support
Licence:
Highslide JS is licensed under a Creative Commons Attribution-NonCommercial 2.5
License (http://creativecommons.org/licenses/by-nc/2.5/).
You are free:
* to copy, distribute, display, and perform the work
* to make derivative works
Under the following conditions:
* Attribution. You must attribute the work in the manner specified by the
author or licensor.
* Noncommercial. You may not use this work for commercial purposes.
* For any reuse or distribution, you must make clear to others the license
terms of this work.
* Any of these conditions can be waived if you get permission from the
copyright holder.
Your fair use and other rights are in no way affected by the above.
Highslide JS is licensed under a Creative Commons Attribution-NonCommercial 2.5 License. This means you need the author's permission to use Highslide JS on commercial websites.
Download without Captions
http://www.mediafire.com/?nyaizmyytoj
Download with Captions
http://www.mediafire.com/?xkfkj1dtocajhd9
FredericP
Post by FredericP » Sat Jun 05, 2010 12:14 pm
Yeeeeeeesssss !
Thx a lot !! I appreciate very very much your efforts. It's very nice !
I will try it now ;-)
[url]http://Peyronnin.fr[/url]
Post by zinc » Sat Jun 05, 2010 12:15 pm
BF Nice & Smooth and another quality work :)
Post by BaconFries » Sat Jun 05, 2010 12:28 pm
@ FredericP enjoy...and thx... :D
@ bendigo thx mate.... :D
jordan
Post by jordan » Sun Jun 06, 2010 9:36 am
S-L-I-D-E IT . :) . very nice again!
+TNX for your index update mail mr.BaconFries . :) .
Post by BaconFries » Sun Jun 06, 2010 1:08 pm
@stempel thx...
@ jordan :D thx for the compliment and the updated index
Post by BaconFries » Sun Jun 13, 2010 11:00 am
Hi Reneke Ok I have just download the extension just to make sure that it is working as it should. I installed into WB opened the extension properties insert the image set the size of thumnail to be used and preview and it working as it should...click on the thumb and it expands to full size...
Can I ask are you inserting a large image or are you just using a thumnail image? the way the extension works is you need to use a large image for both the thumbnail and the large image.. when we insert a large image with say a size of 500x330 you could use a size of 125x75 for the thumbnail so when we click on the thumbnail it will expand to the full size 500x300...
Does the extension work in preview? When you have published have you uploaded all the files needed to make the extension work, if you have a url of the extension can you provide this so i can view and see what may be wrong...
Post by BaconFries » Sun Jun 13, 2010 11:56 am
Hi Reneke glad it is now working for you enjoy... :D
honwahp1
Post by honwahp1 » Thu Jun 17, 2010 11:13 am
I don't know much about extension building but I can tell that this is a nice extenson! Thanks! :)
SKW
Perfect
Post by SKW » Wed Jul 07, 2010 5:16 pm
Just Perfect.
Post by BaconFries » Sat Aug 07, 2010 12:08 pm
Sorry at present this feature is not available in the extension.... :( I may try to add this later ...
If you wish to add a caption to the image then you would need to add this piece of code to each image used changing "caption for the image" to what you need to be displayed.
<div class="highslide-caption">
Caption for the image.
</div>
This is what the HTML looks like note the code in red...
<div>
<a id="thumb1" href="images/acqua.jpg" class="highslide" onclick="return hs.expand(this)">
<img src="images/acqua.jpg" alt="Highslide JS" title="Click to enlarge" height="120" width="107"/></a>
</div>
</div>
Post by BaconFries » Sun Aug 08, 2010 12:58 pm
***updated 8/8/10***
Update to allow the addition of a caption/description for the image.
honwahp1
Post by honwahp1 » Sat Aug 21, 2010 8:23 pm
is it possible that the image be displayed "out of the iframe" as in the other extension (lightbox iframe)?
Post by BaconFries » Sat Aug 21, 2010 10:23 pm
No sorry this is not possible with this extension this feature is only available to the Lightbox iframe extension....
me.prosenjeet
Re: Highslide Single Image Update***08/08/10***
Post by me.prosenjeet » Wed Mar 23, 2011 7:11 pm
Thanks for the caption addon.
A request, in the extension can you use 'type=edit' and "HTML Textbox or Rich Text" so that we can format the text that we want to use as caption. Currently all texts show center alligned
www.Lucknowwebs.com
