jQuery Coin Slider - **Updated Feb. 3, 2011**
protectourlands
Post by protectourlands » Sat Jun 05, 2010 5:26 am
Yes it does.
I have discovered that if I wait for it to cycle all the way around through all the pictures, the pictures do finally appear.
uncle rich
Post by uncle rich » Tue Jun 29, 2010 4:48 pm
@bendigo,
what extension did you use to create sliding effect when you click on home-work-contact-about links? I really like the vertical transition effect.
Post by zinc » Tue Jun 29, 2010 8:39 pm
@uncle rich
@thanksjc
Thank you guys. It an extension by yours truly:
viewtopic.php?t=19374
gp2727
Re: jQuery Coin Slider - **Updated Feb. 3, 2011**
Post by gp2727 » Thu Feb 03, 2011 10:19 pm
Posted Latest Version of jQuery CoinSlider v1.1.1 jQuery embedded and for server neatness, all files publish to single folder called coinslider.
This version will only work in version 7 & up... Enjoy!
giula
Post by giula » Mon Apr 04, 2011 9:12 pm
This extension works great but in IE, while the page loads, look vertically for a few seconds all the images of the slide.
If you do not notice, try reloading the page.
Is it normal?
gp2727
Post by gp2727 » Tue Apr 05, 2011 12:55 am
giula wrote:This extension works great but in IE, while the page loads, look vertically for a few seconds all the images of the slide.
Is it normal?
Yes it is, I previewed the developer's script page in IE and I see the issue you reported.
Will try to code a workaround but no guarantees...
me.prosenjeet
Post by me.prosenjeet » Wed Sep 21, 2011 10:41 am
Extension on a blank page....Keeping default settings.....adding images....preview in Google Chrome, Opera and Safari the images dont show.
Any idea?
www.Lucknowwebs.com
davemoguel
Post by davemoguel » Fri Apr 19, 2013 11:53 pm
This file is currently set to private.
gp2727
Post by gp2727 » Sat Apr 20, 2013 2:00 am
@davemoguel
Yes, the file is set to private by choice. You can choose different galleries add-ons here: http://www.wysiwygwebbuilder.com/free_extras.html
You can easily add this to your website by adding the code listed here: http://workshop.rs/2010/04/coin-slider- ... e-effects/
davemoguel
Post by davemoguel » Fri May 24, 2013 10:49 pm
cant acces to the file...seems private. is there any chance to download it again?
thanks!
gp2727
Post by gp2727 » Sat May 25, 2013 1:07 am
https://dl.dropboxusercontent.com/u/337 ... 111172.wbx
Built with Extension Builder 4.1 for use with Web Builder 8 and above.
