TELL A FRIEND IMAGE V2 - New Features * UPDATE 30/07/2010 *
Are you happy with the new features, was it worth an upgrade?
Yes
24
86%
No
4
14%
Total votes: 28
genieuk
Re: TELL A FRIEND IMAGE V2 - New Features * UPDATE 30/07/20
Post by genieuk » Sat Nov 06, 2010 6:56 pm
Hi Jeff,
I am suggesting just one master page with the extension on and have it then on everypage or whichever pages you want. What you want to do with with unique urls to be sent to users is not possible so at the moment its not worth have multiple versions of the extension on your website. When i update the extension so that it submits the page url the user was on then it will be unique as obviously depending on what page the user is on it will get the url the user is on and send that in the email not just the domain name but the actual url of the webpage they sent the tell a friend message from.
By using a master page you could add the extension to any pages you want and only have one instance of the extension on the server.
Regards,
Mathew
jeff11214
Post by jeff11214 » Sat Nov 06, 2010 6:59 pm
I understand now. I'll be looking out for an update :)
Thank you
genieuk
Post by genieuk » Sat Nov 06, 2010 7:01 pm
jeff11214 wrote:I understand now. I'll be looking out for an update :)
Thank you
Hi Jeff,
As soon as the extension is updated i will update the topic title, first post and make a new reply explaining the update :)
All the Best,
Mathew
