Stay On Top ***23/10/13***
jordan
Post by jordan » Sun Jan 03, 2010 6:01 pm
BaconFries wrote:Image Image Theres no rush on these it was just my way of working of a a little hangover... Image but what you do is Image it just this time of year when I go Image....for the others they can wait....Image
this is working of a hangover ?
(uuuhh ... well actually I can agree in this argument . :mrgreen: .)
but I thought you took my advise and went sleeping.
you must be sleeping and typing with your toes while sleeping then . :lol: :lol: .
INDEX is updated BaconFries! . 8) .
Post by BaconFries » Sat Jan 23, 2010 1:04 pm
This has already been fixed and a new download available for use.... :D
Post by BaconFries » Fri Jun 25, 2010 10:40 am
The extension does not need to be updated the reason why you are having issues is because both extensions Fixed Object and the New slide show both use jquery and are conflicting with each other it will need to be one or the other sorry if you must have both then you would need to modify the source code manually and remove the following line this way you can run both extensions at one time
<script type="text/javascript" src="js/goemo_fixedobject_jquery.min.js"></script>
To remove this line of code you will need to open the HTML source in notepad++ or any other HTML editor look for the line of code above and delete from the source save the changes and upload the page to server the only issue here is if you make any chages in WB with both extensions on the page and save you will need to do this again....
Update on this I have just tested the fixed object with the latest version of jquery and the issue is still the same it is nothing to do with the fixed object it because both extensions use jquery so it wll need to be one or the other as I have already mentioned...
Post by BaconFries » Fri Jun 25, 2010 10:46 pm
Hi ok a update I have managed to figure out a way of using both extensions at once without with causing any errors and without the need to use a iframe i just need to test a bit more by building a demo page with a few objects, shapes, images once this is done I will update and you will be able to download from the usual place
gp2727
Post by gp2727 » Sat Jun 26, 2010 3:52 am
BaconFries wrote:Hi ok a update I have managed to figure out a way of using both extensions at once without with causing any errors and without the need to use a iframe i just need to test a bit more by building a demo page with a few objects, shapes, images once this is done I will update and you will be able to download from the usual place
Good Evening BaconFries,
Did you use the function jQuery.noConflict() or were you able to just change what version jQuery one of the extensions used?
Not being nosy, but this will be a common topic on the forum I think...
Post by BaconFries » Sat Jun 26, 2010 12:33 pm
Afternoon gp nope your not being nosey Image lol yes I am trying the jQuery.noConflict() but inserting it like below so far it seems to work fine...I really want to check with a few of my own and other extensions that use the jQuery looks like I will have one or two to add this two...
jQuery.noConflict();
</script>
Rebel Studio
Re: GOEMO English Translated Fixed Object ***Updated 25/07/1
Post by Rebel Studio » Mon Nov 08, 2010 3:57 pm
It wont let me dl the file because of settings of the owner
gp2727
Post by gp2727 » Mon Nov 08, 2010 4:11 pm
@Rebels I just try to download and I had no problem...Are you using this link: http://www.mediafire.com/?bzsw6c2mblmyb0b
Post by BaconFries » Mon Nov 08, 2010 4:13 pm
Hi rebels sorry about that I have been tidying up all the folders on mediafire with extensions in them...it should now be fine to download.... :)
Rebel Studio
Post by Rebel Studio » Mon Nov 08, 2010 7:01 pm
Thank you it works fine now
Rebel Studio
Post by Rebel Studio » Mon Nov 08, 2010 7:13 pm
But now i wonder if i got the right extention, i want a image that stays on the same spot when the rest of the site is scrolling down. I dont want the effect you get in a layer.
I have red the englisch pdf but i dont get how to insert a image in the extension.
Edit: nvm, figured it out, this was what i was looking for, great!! ty all
smartmedia
Post by smartmedia » Thu Aug 04, 2011 6:05 pm
Bacon this Extention seems to have problem to corroborate with Layer objects. Can you post the source code of the Extension or a similar html code is used...???
I try it with images and is playing ok. I have an issue, i want the image to show up in the right side on the middle of screen, since i don't know the exactly height of Browser window how i will tell him that..??? Normally in other situations i put -1 does that works here...???
infogate
Post by BaconFries » Thu Aug 04, 2011 6:36 pm
You already have the source :? the extension itself is the code/source :? it has all the files used to make it this includes the jQuery and the javscript if you just save the extenion on its own you will have everything used, please note that this extension is only a translated version of the original one by Goemo to make it easier for non German users...
iamafireman
Post by iamafireman » Fri Sep 09, 2011 9:52 pm
Unable to download, says folder set to private, and I dont see it in the extension manager for download.
Post by BaconFries » Fri Sep 09, 2011 9:57 pm
It is set to PVT at the moment trying to work my way through all my extensions and update to the latest version of builder as soon as it is ready it will be available form the extension manager...
