Stay On Top ***23/10/13***
jordan
Post by jordan » Sun Jan 03, 2010 6:01 pm
BaconFries wrote:Image Image Theres no rush on these it was just my way of working of a a little hangover... Image but what you do is Image it just this time of year when I go Image....for the others they can wait....Image
this is working of a hangover ?
(uuuhh ... well actually I can agree in this argument . :mrgreen: .)
but I thought you took my advise and went sleeping.
you must be sleeping and typing with your toes while sleeping then . :lol: :lol: .
INDEX is updated BaconFries! . 8) .
uncle rich
Post by uncle rich » Sat Jan 23, 2010 5:39 am
Am I missing something? I cannot get this extension to work. I installed the extension and entered the object ID, but the image I want to fix does not stick to any of the specified corners.
Post by BaconFries » Sat Jan 23, 2010 1:04 pm
This has already been fixed and a new download available for use.... :D
uncle rich
Post by uncle rich » Sat Jan 23, 2010 3:20 pm
Got it working! This could come in very handy :D
SKW
Post by SKW » Mon Apr 19, 2010 8:21 pm
Perfect.
Thanks very much.
uncle rich
Post by uncle rich » Fri Jun 25, 2010 3:08 am
can someone update this extension. In WB7, it does not play nice with slideshow.
http://jessopfarms.com/Products.html
Post by BaconFries » Fri Jun 25, 2010 10:40 am
The extension does not need to be updated the reason why you are having issues is because both extensions Fixed Object and the New slide show both use jquery and are conflicting with each other it will need to be one or the other sorry if you must have both then you would need to modify the source code manually and remove the following line this way you can run both extensions at one time
<script type="text/javascript" src="js/goemo_fixedobject_jquery.min.js"></script>
To remove this line of code you will need to open the HTML source in notepad++ or any other HTML editor look for the line of code above and delete from the source save the changes and upload the page to server the only issue here is if you make any chages in WB with both extensions on the page and save you will need to do this again....
Update on this I have just tested the fixed object with the latest version of jquery and the issue is still the same it is nothing to do with the fixed object it because both extensions use jquery so it wll need to be one or the other as I have already mentioned...
uncle rich
Post by uncle rich » Fri Jun 25, 2010 9:57 pm
Thanks Baconfries. I got around the problem by using iframe and placing the slideshow on a blank page.
Post by BaconFries » Fri Jun 25, 2010 10:46 pm
Hi ok a update I have managed to figure out a way of using both extensions at once without with causing any errors and without the need to use a iframe i just need to test a bit more by building a demo page with a few objects, shapes, images once this is done I will update and you will be able to download from the usual place
gp2727
Post by gp2727 » Sat Jun 26, 2010 3:52 am
BaconFries wrote:Hi ok a update I have managed to figure out a way of using both extensions at once without with causing any errors and without the need to use a iframe i just need to test a bit more by building a demo page with a few objects, shapes, images once this is done I will update and you will be able to download from the usual place
Good Evening BaconFries,
Did you use the function jQuery.noConflict() or were you able to just change what version jQuery one of the extensions used?
Not being nosy, but this will be a common topic on the forum I think...
Post by BaconFries » Sat Jun 26, 2010 12:33 pm
Afternoon gp nope your not being nosey Image lol yes I am trying the jQuery.noConflict() but inserting it like below so far it seems to work fine...I really want to check with a few of my own and other extensions that use the jQuery looks like I will have one or two to add this two...
jQuery.noConflict();
</script>
Rebel Studio
Re: GOEMO English Translated Fixed Object ***Updated 25/07/1
Post by Rebel Studio » Mon Nov 08, 2010 3:57 pm
It wont let me dl the file because of settings of the owner
gp2727
Post by gp2727 » Mon Nov 08, 2010 4:11 pm
@Rebels I just try to download and I had no problem...Are you using this link: http://www.mediafire.com/?bzsw6c2mblmyb0b
Post by BaconFries » Mon Nov 08, 2010 4:13 pm
Hi rebels sorry about that I have been tidying up all the folders on mediafire with extensions in them...it should now be fine to download.... :)
Rebel Studio
Post by Rebel Studio » Mon Nov 08, 2010 7:01 pm
Thank you it works fine now
