Wobbling 3D Carousel
Eddy
Post by Eddy » Sun Oct 25, 2009 2:51 pm
Original its a text carousel with one color and no target but I changed it to real
textlinks and now you can use it as a menu on your page.
I have given the linkstyle: link,hover and visited the same color what looks nicer.
You have the option to use three colors in the carousel.
The text renders the best on dark backgrounds but not on white backgrounds in IE.
I have made a little image to center the carousel on your page,the carousel is visible in previeuw.
Al files/scripts are in one folder to have a nice clean html page.
1) Select url
2) Target
3) textcolor
4) linktext ( use short words)
5) And a few other settings.
ExtBuilder:Eddy.
Developer:Shawn.
http://www.devirtuoso.com/
Download for WB 6.5 ( pdf included. )
http://www.mediafire.com/file/i2nfxxv2z ... _valid.zip
madjamonline
Post by madjamonline » Sun Oct 25, 2009 2:52 pm
That is pretty awesome! I am downloading...
jordan
Post by jordan » Tue Oct 27, 2009 1:55 pm
I knew I would ... lOve this extension Eddy.
Especially combined with your PhotoWidget on one page ... looks sMash!.
thx . 8) .
+ tnx for your index update mail.
Eddy
Post by Eddy » Tue Oct 27, 2009 7:30 pm
Thanks,I always search for nice extensions. :D
Eddy
Post by Eddy » Tue Dec 29, 2009 11:27 am
Meets W3C Standards
Built with Extension Builder 2.0.2
rotgerus
Re: Wobbling 3D Carousel
Post by rotgerus » Tue May 24, 2011 2:30 pm
De draai snelheid is erg snel en mij wil het niet lukken om hem langzamer te laten draaien.
Heb hem op 2000 staan maar dat is nog veel te snel en lager instellen kan niet?
Wie weet raad?
gr,Rotgerus :?:
Post by BaconFries » Tue May 24, 2011 4:12 pm
English please as Eddy is no longer on the forum and wont read this, otherwise non dutch speaking members wont be able to help.....
rotgerus
Post by rotgerus » Tue May 24, 2011 5:35 pm
The speed is to fast, i have it on 2000 and stil is it to fast.
I whant a slower speed, how can help
Post by BaconFries » Tue May 24, 2011 9:24 pm
The only way to be able to decrease the speed would to be manually change the setting within the settings.js file, you would need to open the file in Notepad++ and look for var speed = 3000; then save the file and upload to your server, note that you need do this each time that you made any changes to it in WB or rebuild the extension and change the variable to allow this.....
WB10user
Post by WB10user » Tue Mar 29, 2016 1:26 pm
Can a person add images to this extension or is it just text only?
Thanks.
Post by BaconFries » Tue Mar 29, 2016 3:49 pm
Please note that the developer of this extension is no longer active in the forum so there is no support with it.
Hurtado
Post by Hurtado » Mon Sep 12, 2016 12:23 pm
Fake
Link to ads
Post by BaconFries » Mon Sep 12, 2016 12:31 pm
It is not a fake please look at the original date of this thread it is 7years old and at that time the link was valid the site may no longer be in use and the link hijacked. Also note that the original builder of this extension is no longer active. Before commenting you should always read the original post carefully including dates of thread. Note again the mediafire link is still valid but if used there is no support with the extension
Hurtado
Post by Hurtado » Thu Sep 15, 2016 4:00 pm
Link to ads
Post by BaconFries » Thu Sep 15, 2016 6:02 pm
As already mentioned to you the link is 7 yrs old now. At the original time the link did not lead to ads but to the original script site. I will remove it if it really bothers you that much!! :?
Users browsing this forum: No registered users and 6 guests
