Slider Effect Menu Updated***05/10/12***
Post by BaconFries » Tue Mar 30, 2010 9:15 pm
Thx gp.... got them thx as my email I will test tomorrow ... :D
Post by BaconFries » Fri Apr 02, 2010 2:39 pm
Extension has been updated to have active state menu to show which page your on
iamafireman
Post by iamafireman » Sat Apr 03, 2010 2:53 am
great will try it out
MP3
Post by MP3 » Mon May 24, 2010 5:12 pm
This new update does not work for me.
The page you stay on is not underlined or highligted, the slider goes back to the HOME page. :(
Franky
Post by BaconFries » Mon May 24, 2010 5:48 pm
Have you downloaded the correct extension there are two version one without active state the other without...
Download For Web Builder Version 6.5 without active state
Download For Web Builder Version 6.5 with active state
Did you read the PDF on how to set the active state see images below note you only set one page to active state all other you leave to 0
Note it is not the text that gets Highlighted but the slider below..I have also just checked the extension and it seems to work fine here...
:D
MP3
Post by MP3 » Tue May 25, 2010 1:54 pm
Well BF, I did exactly what reported and doubled checked it.
No way to fix it for me !!!! :?
Franky
Post by BaconFries » Tue May 25, 2010 2:52 pm
Here is a demo wbs showing the menu on four pages Home, About,Gallery,Contact the choosing page shows the page tilte under the page name/title in the slide menu it will show a white slider line this will move/slide when you click to view another page and will show the slide under the tiltle of the new choosing page I have also included the extension that I am using with the wbs i uploaded...
http://www.mediafire.com/?z3dldymztbi
mbrowne
Post by mbrowne » Mon Aug 16, 2010 1:44 am
Odd. I just tried the active state version, and I can't get it to show either. Must be a strange quirk. I'm using WB v6.57 on XP. The set-up is simple enough, and I have no other scripts. Dunno...
gp2727
Post by gp2727 » Mon Aug 16, 2010 3:22 am
mbrowne wrote:Odd. I just tried the active state version, and I can't get it to show either. Must be a strange quirk. I'm using WB v6.57 on XP. The set-up is simple enough, and I have no other scripts. Dunno...
You have to select a background file for the menu to show (extension includes folder with many different types)....Has that step occurred?
mbrowne
Post by mbrowne » Mon Aug 16, 2010 5:55 am
Yes. But I think I was not clear. I was referring to mp3's issue of not being able to get the "active state" to show. The rest works fine. The active page just is not indicated by the menu.
v84x4
Post by v84x4 » Mon Aug 16, 2010 12:42 pm
You the Man BaconFries
This extenion is just what i was l@@king for
Thanks for your hard work.....
Your getting real good at this
Best regards V8
Post by BaconFries » Mon Aug 16, 2010 12:51 pm
Well thank you V8 I had input from gp2727 with the active state as my original version didnt have this feature....
v84x4
Post by v84x4 » Mon Aug 16, 2010 1:06 pm
Ohhhh :shock:
Wow....i just tried it and OMG.....Its Great 8)
I think all future extention should have the abillity
to use you own background image, just like this one.....
This is an amazing & wanted capability for me
cant wait to put it to good use on some cool templates
BaconFries gets 5 stars
V8
mbrowne
Post by mbrowne » Mon Aug 16, 2010 3:56 pm
BaconFries wrote:Well thank you V8 I had input from gp2727 with the active state as my original version didnt have this feature....
Is there anything simple that I might be overlooking that keeps me from getting the active state to work. I test it with only a few simple pages with nothing but a small text object and your menu.
v84x4
Post by v84x4 » Mon Aug 16, 2010 4:26 pm
Well........let me try :wink:
Background folder that comes with extention needs to go in the:
my documents/WYSIWYG Web Builder/system( folder)
along with extention
Is this what you are asking?
Regards V8
