Google Maps API v3 ***Re-Released 17/07/2014*** (Deprecated)
smartmedia
Re: Google Maps API v3 ***Update 15/03/11***
Post by smartmedia » Thu Mar 17, 2011 10:03 am
Hi..
Any idea how to find the right longitude and latitude for a place..?? I download and install Google earth, i got some test long, lat, i put it but didn't worked. Do i need to transform those into special form...???
infogate
Post by BaconFries » Thu Mar 17, 2011 11:08 am
Yer try this site from fellow member neo_webbuilder just enter the full address needed example 101, yourstreet/road, yourtown, yourcountry, yourzip/postcode
http://www.backups.nl/geocoder.html
Post by BaconFries » Tue Mar 22, 2011 5:49 pm
No the API key is no longer required
Post by BaconFries » Thu Apr 21, 2011 9:43 pm
I will try and take a look over the next couple of days and see what can be wrong
JimmyJazz
Post by JimmyJazz » Sat Apr 23, 2011 9:02 am
BaconFries wrote:
For example JOES BURGERS will work; JOE'S BURGERS will not.
Try this
JOE&rsquo;S BURGERS
I just spent 4 hours trying to get a new map working & then I come to here & find the answer right in front of me.
Thanks to BaconFries for keeping on top of this fantastic extension :D
Post by BaconFries » Sat Apr 23, 2011 10:10 am
Thanks Jimmy always nice to read compliments form a user of the extension...note I have made a couple of changes to the extension and will be releasing soon...it not a requirement to update to the newer only if you need to show the placement of tye navigation buttons in the map I am still testing and need to update the pdf before I ca release once again thanks for the compliments... :D
JimmyJazz
Post by JimmyJazz » Sat Apr 23, 2011 11:25 am
Hi BaconFries,
ok, noted.
Re: Google Maps API v3 ***Update 24/04/11***
Post by BaconFries » Sun Apr 24, 2011 9:23 pm
***Updated 24/04/11***
Post by BaconFries » Tue May 03, 2011 5:02 pm
Can you say what is happening? as I have just checked and if I set the streetview to false then the icon doesnt get displayed this is how it is ment to work, and if it is set to true then it will display see images below
Post by BaconFries » Tue Jun 07, 2011 3:43 pm
Hi when I first rebuilt this version of the map API V3 it did have a offset in the code, but I had to remove it because it was causing the map icon to be put out of place and not showing the said latittude/longitude position of the location that the user inserted into the extension variables. I will check if I still have a copy of that on Mediafire or backed up and a pendrive If either is the case I will post it temporarily for you to try it out and se it it is what you need...
Post by BaconFries » Tue Jun 07, 2011 5:08 pm
No problem I was working on this map from DD but due to a Hard drive crash I lost all files take a look here
http://www.dynamicdrive.com/dynamicinde ... lector.htm
Post by BaconFries » Tue Jun 07, 2011 5:40 pm
Hmmm are you using the latest version of the extension?? there shouldnt be any issues using that latest...
Post by BaconFries » Tue Jun 07, 2011 6:29 pm
Looks like you have not set the width,height for the shadow see image below this should fix it for you
Post by BaconFries » Tue Jun 07, 2011 7:42 pm
:) Great that you got it fixed ...wasnt there a selection of icons in the zip file with the extension when you downloaded... :?:
Post by BaconFries » Tue Jun 07, 2011 8:13 pm
Ok I will post a link later for you to grab a selection of map icons that you can use on the map...:)
