5 Star + Thumb + Hearts Rate Extension + translate variable
Post by BaconFries » Sun Apr 26, 2009 12:35 pm
WOW as the words of the song......
"Things can only get better Can only get better"
thx Eddy......
Eddy
Post by Eddy » Sun Apr 26, 2009 2:09 pm
What are the difference between the 1st (with translation) and the others
I did write an answer in the first post.
rolo
Php Rater Bug
Post by rolo » Tue Jun 09, 2009 11:56 pm
I insert the php rater in a wysiwyg .php page.
When published, I get this error:
Warning: fopen(item_1.rating) [function.fopen]: failed to open stream: Permission denied in /home/todo/domains/mydomain.com/public_html/prueba/rater.php on line 86
Warning: fclose(): supplied argument is not a valid stream resource in /home/todo/domains/mydomain.com/public_html/prueba/rater.php on line 87
Any idea on how to fix it?
Eddy
Post by Eddy » Wed Jun 10, 2009 10:02 am
There are two files,the proses file and the rate file.
check the file permissions - they are probably set in a way that the web server cannot open it.
Cmod to 755 or 777
Look also if php safe mode is off.
rolo
Post by rolo » Thu Jun 11, 2009 11:59 am
I only have Rater.php file (with chmod 777)
and a Stars dir with png files.
1) Where can I find "Rater" and "Proses" files you mention ?
2) How can I know if I have php safe mode off in cpanel ?
Thanks !
Eddy
Post by Eddy » Thu Jun 11, 2009 12:18 pm
The rate file what stores the ratings is generated after the first rating on your server.(item_1.rating)
On your server.
You can ask your hosting compagny.
Ask them also about the error message ,maybe they know how to solve it or what they have to change on the server to make it work.
This is where you have the error,
 fclose($rater_file);
}else{
 $rater_file=fopen($rater_filename,"w");
Eddy
Post by Eddy » Tue Jul 07, 2009 12:37 am
Have u tried changing the permission to 777 right after the file item1.rating is created?
cmod the file item1.rating to 777
Please contact your hosting maybe they can help you if cmod to 777 das not solve your problem.
v84x4
Post by v84x4 » Sat Sep 19, 2009 6:26 pm
hey...
I was messing around with the NEW star rater (80 max)
I deleted (item_1.rating ) from my server & now when I re-upload the Star rater extention
the upload dosnt put the nessesary file back...........hmmmm
I have tried uploading the entire site to get it to work but still
wont upload the file item_1.rating
See example here http://www.highwaytrucker.com/talent.php
Regards V8
Eddy
Post by Eddy » Sat Sep 19, 2009 8:19 pm
item_1.rating is generated on your server after the first rating,please read previous posts about the same problem.
It looks that the rater das not work on your server ,something on your server is not configured for this script ( fopen) I have read this from other users to but dont know how to change the php to make it work on al servers.
Contact your hosting maybe they know what todo. :?
Your error code:
Warning: fopen(item_5.rating) [function.fopen]: failed to open stream: Permission denied in /home/v84x4/public_html/rater.php on line 35
Warning: fread(): supplied argument is not a valid stream resource in /home/v84x4/public_html/rater.php on line 37
Warning: fwrite(): supplied argument is not a valid stream resource in /home/v84x4/public_html/rater.php on line 60
Warning: fclose(): supplied argument is not a valid stream resource in /home/v84x4/public_html/rater.php on line 63
Warning: fopen(item_5.rating) [function.fopen]: failed to open stream: Permission denied in /home/v84x4/public_html/rater.php on line 86
Warning: fclose(): supplied argument is not a valid stream resource in /home/v84x4/public_html/rater.php on line 87
Maybe you can use this?
http://nl2.php.net/function.fopen
v84x4
Post by v84x4 » Mon Sep 21, 2009 2:59 am
I manually created the item_1.rate and then chmod it to 666. All works now.
Thank you eddy This is a great estention
Regards V8
Eddy
Post by Eddy » Mon Sep 21, 2009 6:51 am
manually created the item_1.rating and then chmod it to 666.
Never thought about that,maybe this works for others to :?
Eddy
Post by Eddy » Wed Sep 23, 2009 4:42 pm
Open notepad.
Save a new page as item_1.rating
Upload that empty page to your server in the same directorie as rate.php and cmod to 666.
Or look first in the php file for the exact name:
Open rater.php and look to the raterID "rating" for the exact name after item_1.
// DO NOT MODIFY BELOW THIS LINE
$rater_filename='item_'.$rater_id.".rating";
v84x4
Post by v84x4 » Wed Sep 23, 2009 5:32 pm
Thanks Eddy
It worked but now Im having a problem using "Star Rater" with "Form" with submit button
When I hit "Rate" it mixes up with the "Submit" button on the form
See Here http://highwaytrucker.com/talent.php
Regards V8
Eddy
Post by Eddy » Wed Sep 23, 2009 5:56 pm
The form prosesses the rater after submit and thats what the form prosessor from webbuilder shut do,it proseses all forms in your page.
I think the best thing todo is:
Make the form on another page and show the form in an iframe page.
v84x4
Post by v84x4 » Wed Sep 23, 2009 7:07 pm
:wink:
Ahhhh,
Good Idea Eddy
Once again...........Your the man
Best Regards V8
